LIFX Local Control
Minor update here available from the usual place (see first post in this topic I think!)
  • Discovery scanning speed is improved.
  • Added a preference input for one or more IP subnets e.g. 192.168.0 for the cases when the LIFX bulbs are on a different subnet from the hub. I'm not 100% sure this works, since I only use a single subnet at home, but as long as UDP traffic can pass between subnets then there shouldn't be any issues. This field is relatively forgiving, you can specify 192.168.1 or 192.168.1. or even 192.168.1.1 - all these will be taken as 192.168.1.
Sorry, I haven't put version numbers in yet.
