Very odd, I get that same message in the LIFX app, but when I try to update firmware it says all my devices are up to date, although it looks as though they're all on 3.60 which is from around 2020 I think.
Same for me, I'm in the US. I think they pushed the message to all users in the app, without checking what bulbs are actually registered on the account.
From the LIFX release page, it looks like older chipsets are not being updated. I haven't bought any new bulbs in a couple years, some are on 3.60 and some still on 2.77
I auto-updated all bulbs. No problems. I have some older BR30 bulbs that show firmware v2.9 now but newer bulbs show v3.9 now. I didn't check prior to the update. I have about ten bulbs in use currently and they have always worked perfectly. My first and favorite smart bulbs even if they are WiFi. I used them in a rental house I was staying in temporarily and wanted to smarten up without altering the wiring. I just taped the wall switches on. That was in my SmartThings days. Life was simpler then ....
No, this is primarily for cases where the bulbs are also controlled outside of Hubitat -- the polling enables Hubitat to periodically update its view of the bulb state to match the current actual state.
It looks like that the "great news"-firmware update has changed the MAC-adress of my 3 bulbs.
I can tell because I made a DHCP export before moving from Fritz-Box to UDM.
I added reservations for them on UDM and after the upgrade they obtained random IP-adresses and therefore had not been controllable by the Hub anymore.
No and that shouldn't be possible like that.... Pull the bulb and the mac addr should be on the side of the bulb. It should match any pings you do to it.
Thanks, I am aware that a MAC is supposed to be a unique adress, but I wonder why the reservations with the former MAC were still persistant for the UDM and had to be deleted before adding them again with the old IP-adresses?
And of course I did some power-cycles before.
I don't believe it's utilized in the built-in drivers -- @bcopeland fixed the associated Java Class defined within Hubitat, which unblocked my attempts to use it in my community "enhanced" driver -- but still not exposed directly as a raw "command" to be invoked.
Can we please add an option to the driver to consider an "unresponsive" bulb as "Off"?
I have a couple of bulbs that get turned off at the light switch but, because they never show as "off", my automations to auto-turn-off the Laundry light et al never activate as HE thinks the lights never change state.
