Life 360 wont set location
Me too. The Life360 WEB portal has gone so no way to use the Hubitat inbuilt Life360 app anymore as it doesn't show Places.
Any chance of a fix!
Any solution for this? I just need a reliable means of geofencing.
If you use iOS, look into Geofency. Works very well.
You can still use life 360. I found a way!
What you need to do is join a second person to your account. Then use them to authorize the place from there mobile. Once done you can remove them.
This is what I did and it worked fine. Just a bit of a pain!
I did contact Life360 and they are not interested at all.
This worked perfectly. Thank you!!
I'll try this when I get some time to sit down and go through it. There seem to be some good ideas in here. Thank you for taking the time to share.
I think i have it set up, but I'm testing by changing between move and significant monitoring and I'm not seeing any logging or events. Any ideas?
My locations are all in the Monitored list. If you select one with the 3 vertical dots, and then Settings, Webhook, make sure HTP Method is POST (JSON). Then select Enter or Exit. What message do you get?
Also, did you turn on Debug Mode in the Geofency App?
Since I'm on Android, I used OwnTracks. Forgive me but I'm a bit of a newbie and don't recognize those things to look for. I've poked around and I'm not finding them.
I can't help you then. I assumed you were using Geofency on iOS. Sorry.
No problem. Thanks anyway.
