My Hubitat has been controlling a security power socket for several months now without issue.
I have just noticed that for the past few days the socket has been 'On' when it should have been 'Off'.
I notice that the Life360 Condition is not showing correctly in Rule Machine. It is showing a 'True' when it should be showing a 'False'. The App on my phone is showing the correct locations though, so it appears to be something to do with the Life360 Connector. Life360 Connector appears to be logged in so I am not sure what to check after that.
Any help would be very much appreciated.
The Life 360 "Places" for your home is the important part to make sure Hubitat is setup to use the correct place and it's radius is set how you need it in Life 360. On Hubitat there should be a Life 360 Refresh option that you can press to see if it updates correctly.
Thanks for that suggestion tterk1.
As all occupants will need to be away; I'll need a couple of days to monitor the changes as they take place. I'll get back with an update then.
