Silly question
Are you sure that the refresh is doing nothing?
If you have a separate browser window, open to the logging page, and hit the refresh button it normally makes a couple of entries in the logs.
Ok..
Normally oauth is set when the code is installed on the hub.
As we don’t have access to this code or setting for in-built apps I would suggest that maybe it didn’t install correctly
Have you tried uninstalling the app completely, reauthorising you account etc and trying again?
That would be my next troubleshooting step
BTW keep a logging window open at the same time as installing to try and ‘catch’ any installation errors that may not show any other time.
Edit: I would personally also reboot the hub after uninstall just to ‘clear the decks’ and clean everything out of memory before the reinstall
My plugin runs on multiple systems without issue using the same account.
Or are you stating that it won't work on more than one Hubitat system because of the Webhook you push to Life360 during the app setup for the enter/exit of places?
If it's won't work on more than 1 Hubitat install at a time then I understand it.
What we have observed is that their webhook only supports one endpoint. I cant speak for other integrations, but running the st integration with the same account as the running he integration won't work.
Yes. Login shows OK, my circle name is there, my place name is there, and the people names are there.
We'll be leaving the house soon, so I'll get to test it in a few hours.
As a side test, I also setup an IFTTT applet to change a test present sensor in Hubitat when everyone leaves. If it works, I can at least use that as a workaround.
