I have tried to use the old unmaintained drive, but am getting these kind of errors:
2023-05-09 03:10:42.694 AMerrorDryer MQTT Error: Error: Connection lost: Connection lost
dev:2912023-05-09 03:08:17.851 AMwarnDryer Lost connection to MQTT, retrying in 15 seconds java.lang.NullPointerException: Cannot get property 'privateKey' on null object
dev:2912023-05-09 03:07:34.521 AMwarnDryer Lost connection to MQTT, retrying in 15 seconds java.lang.NullPointerException: Cannot get property 'privateKey' on null object
dev:2912023-05-09 03:06:23.420 AMwarnDryer Lost connection to MQTT, retrying in 15 seconds java.lang.NullPointerException: Cannot get property 'privateKey' on null object
dev:2912023-05-09 03:05:26.994 AMerrorDryer MQTT Error: Error: Connection lost: Connection lost
dev:2912023-05-08 07:26:36.643 PMerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_dcm_thinq_LG_ThinQ_Dryer_735.off() is applicable for argument types: () values: []
Possible solutions: run(), run(), any(), is(java.lang.Object), use([Ljava.lang.Object;), any(groovy.lang.Closure) (method off)
dev:2912023-05-08 07:26:22.045 PMerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_dcm_thinq_LG_ThinQ_Dryer_735.on() is applicable for argument types: () values: []
Possible solutions: run(), run(), any(), is(java.lang.Object), any(groovy.lang.Closure), run(java.io.File, [Ljava.lang.String;) (method on)
Looks pretty broken, but I am not a groovy expert.
Any thoughts from anyone on how to proceed?
