@tomw & @dsegall ,
I followed the following outlined steps in order to generate the log attached further below. Hopefully this gives you enough to follow -- let me know if there is anything more specific I can do to help track it down. Thank you both for all the work you've put into this!
- Started with Kitchen Dimmer Off (last level 100%), “cansetlevel=false”.
- Set level 50% - nothing
- Turn light on, cansetlevel flicker to true and then false
- Set level 60% - nothing
- Refresh – cansetlevel changes to true.
- Set level 50% - works, but canSetlevel changes back to false.
- Set level 80% - nothing
- Refresh – cansetlevel changes back to true.
- Set level 80% - works.
Events from Device (Kitchen Dimmer):
| canSetLevel |
false |
DEVICE |
2021-06-20 06:26:18.895 PM EDT |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:26:18.577 PM EDT |
| canSetLevel |
false |
DEVICE |
2021-06-20 06:26:18.538 PM EDT |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:26:18.258 PM EDT |
| level |
80 |
DEVICE |
digital |
2021-06-20 06:26:18.234 PM EDT |
| canSetLevel |
false |
DEVICE |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:26:17.992 PM EDT |
| canSetLevel |
false |
DEVICE |
2021-06-20 06:26:17.924 PM EDT |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:26:15.578 PM EDT |
| canSetLevel |
false |
DEVICE |
2021-06-20 06:26:01.717 PM EDT |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:26:01.444 PM EDT |
| canSetLevel |
false |
DEVICE |
2021-06-20 06:26:01.390 PM EDT |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:26:01.112 PM EDT |
| canSetLevel |
false |
DEVICE |
2021-06-20 06:26:01.022 PM EDT |
| level |
50 |
DEVICE |
digital |
2021-06-20 06:26:01.021 PM EDT |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:26:00.801 PM EDT |
| canSetLevel |
false |
DEVICE |
2021-06-20 06:26:00.767 PM EDT |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:25:56.955 PM EDT |
| canSetLevel |
false |
DEVICE |
2021-06-20 06:25:39.786 PM EDT |
| canSetLevel |
true |
DEVICE |
2021-06-20 06:25:39.242 PM EDT |
| switch |
on |
DEVICE |
digital |
2021-06-20 06:25:39.120 PM EDT |
Hubitat Logs:
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:18.880 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"chgReason":3,"lastUpdated":"2021-06-20T22:26:14.705Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:18.574 pm [**debug**](http://///Local IP////device/edit/310)respData = [name:Kitchen Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:80, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_0006_DDBF, version:1.5.72; CP 1.9, minLevel:1, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:AAAAAA==, buttonData:null, linkData:null, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.38, created:2019-09-27T20:26:42.000Z, lastUpdated:2021-06-20T22:26:14.356Z, random:false, isRandomEnabled:false, rssi:-55, residenceId:229239, residentialRoomId:null, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153889329, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-07-EB-10, logging:0, resOcc:0, customType:null, iotBridgeId:null, iotBridgeSerial:null, id:406587]
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:18.564 pm [**debug**](http://///Local IP////device/edit/310)httpAsyncCallback **with** status = 200 **from** data = null
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:18.532 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"fadeOnTime":0,"fadeOffTime":0,"lastUpdated":"2021-06-20T22:26:14.356Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:18.359 pm [**debug**](http://///Local IP////device/edit/310)httpPutExec([uri:https://my.leviton.com/api/IotSwitches/406587, headers:[Authorization:///authorization token removed by me///], contentType:application/json, body:[fadeOnTime:0, fadeOffTime:0]])
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:18.316 pm [**debug**](http://///Local IP////device/edit/310)restoreFadeTime **with** data=[state:ON, level:80, currFadeOnTime:0, currFadeOffTime:0, duration:0]
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:18.262 pm [**debug**](http://///Local IP////device/edit/310)Scheduling restoreFadeTime **for** 0s **with** data=[state:ON, level:80, currFadeOnTime:0, currFadeOffTime:0, duration:0]
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:18.250 pm [**debug**](http://///Local IP////device/edit/310)fadeDone **with** status = 200 **from** data = [state:ON, level:80, currFadeOnTime:0, currFadeOffTime:0, duration:0]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:18.226 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"power":"ON","brightness":80,"lastUpdated":"2021-06-20T22:26:14.022Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:18.022 pm [**debug**](http://///Local IP////device/edit/310)httpPutExec([uri:https://my.leviton.com/api/IotSwitches/406587, headers:[Authorization:///authorization token removed by me///], contentType:application/json, body:[power:ON, brightness:80]])
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:17.990 pm [**debug**](http://///Local IP////device/edit/310)fadeStart **with** status = 200 **from** data = [state:ON, level:80, currFadeOnTime:0, currFadeOffTime:0, duration:0]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:17.918 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"fadeOnTime":0,"fadeOffTime":0,"lastUpdated":"2021-06-20T22:26:13.741Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:17.693 pm [**debug**](http://///Local IP////device/edit/310)httpPutExec([uri:https://my.leviton.com/api/IotSwitches/406587, headers:[Authorization:///authorization token removed by me///], contentType:application/json, body:[fadeOnTime:0, fadeOffTime:0]])
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.585 pm [**debug**](http://///Local IP////device/edit/5)updating child: Kitchen Dimmer **with** power: ON **and** brightness: 50
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.574 pm [**debug**](http://///Local IP////device/edit/5)found existing child: Kitchen Dimmer
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.572 pm [**debug**](http://///Local IP////device/edit/5)manageChildDevice(Kitchen Dimmer, 406587)
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.568 pm [**debug**](http://///Local IP////device/edit/5)thisSwitch = [name:Kitchen Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:50, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_0006_DDBF, version:1.5.72; CP 1.9, minLevel:1, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:AAAAAA==, buttonData:null, linkData:null, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.38, created:2019-09-27T20:26:42.000Z, lastUpdated:2021-06-20T22:25:58.000Z, random:false, isRandomEnabled:false, rssi:-55, residenceId:229239, residentialRoomId:null, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153889329, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-07-EB-10, logging:0, resOcc:0, customType:null, iotBridgeId:null, iotBridgeSerial:null, id:406587]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.552 pm [**debug**](http://///Local IP////device/edit/5)updating child: Living Room Dimmer **with** power: ON **and** brightness: 100
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.549 pm [**debug**](http://///Local IP////device/edit/5)found existing child: Living Room Dimmer
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.546 pm [**debug**](http://///Local IP////device/edit/5)manageChildDevice(Living Room Dimmer, 388409)
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.542 pm [**debug**](http://///Local IP////device/edit/5)thisSwitch = [name:Living Room Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:100, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_000B_D1F4, version:1.5.72; CP 1.13, minLevel:10, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:, buttonData:, linkData:, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.20, created:2019-08-24T01:13:49.000Z, lastUpdated:2021-06-20T21:56:43.000Z, random:false, isRandomEnabled:false, rssi:-33, residenceId:229239, residentialRoomId:275242, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153696769, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-0C-F0-09, logging:0, resOcc:0, customType:dimmer, iotBridgeId:null, iotBridgeSerial:null, id:388409]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.534 pm [**debug**](http://///Local IP////device/edit/5)resp.data = [[name:Living Room Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:100, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_000B_D1F4, version:1.5.72; CP 1.13, minLevel:10, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:, buttonData:, linkData:, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.20, created:2019-08-24T01:13:49.000Z, lastUpdated:2021-06-20T21:56:43.000Z, random:false, isRandomEnabled:false, rssi:-33, residenceId:229239, residentialRoomId:275242, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153696769, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-0C-F0-09, logging:0, resOcc:0, customType:dimmer, iotBridgeId:null, iotBridgeSerial:null, id:388409], [name:Kitchen Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:50, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_0006_DDBF, version:1.5.72; CP 1.9, minLevel:1, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:AAAAAA==, buttonData:null, linkData:null, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.38, created:2019-09-27T20:26:42.000Z, lastUpdated:2021-06-20T22:25:58.000Z, random:false, isRandomEnabled:false, rssi:-55, residenceId:229239, residentialRoomId:null, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153889329, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-07-EB-10, logging:0, resOcc:0, customType:null, iotBridgeId:null, iotBridgeSerial:null, id:406587]]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:15.207 pm [**debug**](http://///Local IP////device/edit/5)httpGetExec([uri:https://my.leviton.com/api/Residences/229239/iotSwitches, headers:[Authorization:///authorization token removed by me///], contentType:application/json])
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:01.703 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"chgReason":3,"lastUpdated":"2021-06-20T22:25:57.524Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:01.444 pm [**debug**](http://///Local IP////device/edit/310)respData = [name:Kitchen Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:50, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_0006_DDBF, version:1.5.72; CP 1.9, minLevel:1, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:AAAAAA==, buttonData:null, linkData:null, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.38, created:2019-09-27T20:26:42.000Z, lastUpdated:2021-06-20T22:25:57.209Z, random:false, isRandomEnabled:false, rssi:-55, residenceId:229239, residentialRoomId:null, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153889329, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-07-EB-10, logging:0, resOcc:0, customType:null, iotBridgeId:null, iotBridgeSerial:null, id:406587]
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:01.413 pm [**debug**](http://///Local IP////device/edit/310)httpAsyncCallback **with** status = 200 **from** data = null
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:01.384 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"fadeOnTime":0,"fadeOffTime":0,"lastUpdated":"2021-06-20T22:25:57.209Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:01.216 pm [**debug**](http://///Local IP////device/edit/310)httpPutExec([uri:https://my.leviton.com/api/IotSwitches/406587, headers:[Authorization:///authorization token removed by me///], contentType:application/json, body:[fadeOnTime:0, fadeOffTime:0]])
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:01.185 pm [**debug**](http://///Local IP////device/edit/310)restoreFadeTime **with** data=[state:ON, level:50, currFadeOnTime:0, currFadeOffTime:0, duration:0]
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:01.123 pm [**debug**](http://///Local IP////device/edit/310)Scheduling restoreFadeTime **for** 0s **with** data=[state:ON, level:50, currFadeOnTime:0, currFadeOffTime:0, duration:0]
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:01.110 pm [**debug**](http://///Local IP////device/edit/310)fadeDone **with** status = 200 **from** data = [state:ON, level:50, currFadeOnTime:0, currFadeOffTime:0, duration:0]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:01.014 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"power":"ON","brightness":50,"lastUpdated":"2021-06-20T22:25:56.839Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:00.842 pm [**debug**](http://///Local IP////device/edit/310)httpPutExec([uri:https://my.leviton.com/api/IotSwitches/406587, headers:[Authorization:///authorization token removed by me///], contentType:application/json, body:[power:ON, brightness:50]])
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:00.796 pm [**debug**](http://///Local IP////device/edit/310)fadeStart **with** status = 200 **from** data = [state:ON, level:50, currFadeOnTime:0, currFadeOffTime:0, duration:0]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:26:00.760 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"fadeOnTime":0,"fadeOffTime":0,"lastUpdated":"2021-06-20T22:25:56.584Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:26:00.575 pm [**debug**](http://///Local IP////device/edit/310)httpPutExec([uri:https://my.leviton.com/api/IotSwitches/406587, headers:[Authorization:///authorization token removed by me///], contentType:application/json, body:[fadeOnTime:0, fadeOffTime:0]])
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.952 pm [**debug**](http://///Local IP////device/edit/5)updating child: Kitchen Dimmer **with** power: ON **and** brightness: 100
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.949 pm [**debug**](http://///Local IP////device/edit/5)found existing child: Kitchen Dimmer
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.946 pm [**debug**](http://///Local IP////device/edit/5)manageChildDevice(Kitchen Dimmer, 406587)
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.942 pm [**debug**](http://///Local IP////device/edit/5)thisSwitch = [name:Kitchen Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:100, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_0006_DDBF, version:1.5.72; CP 1.9, minLevel:1, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:AAAAAA==, buttonData:null, linkData:null, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.38, created:2019-09-27T20:26:42.000Z, lastUpdated:2021-06-20T22:25:36.000Z, random:false, isRandomEnabled:false, rssi:-55, residenceId:229239, residentialRoomId:null, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153889329, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-07-EB-10, logging:0, resOcc:0, customType:null, iotBridgeId:null, iotBridgeSerial:null, id:406587]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.927 pm [**debug**](http://///Local IP////device/edit/5)updating child: Living Room Dimmer **with** power: ON **and** brightness: 100
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.924 pm [**debug**](http://///Local IP////device/edit/5)found existing child: Living Room Dimmer
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.921 pm [**debug**](http://///Local IP////device/edit/5)manageChildDevice(Living Room Dimmer, 388409)
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.918 pm [**debug**](http://///Local IP////device/edit/5)thisSwitch = [name:Living Room Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:100, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_000B_D1F4, version:1.5.72; CP 1.13, minLevel:10, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:, buttonData:, linkData:, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.20, created:2019-08-24T01:13:49.000Z, lastUpdated:2021-06-20T21:56:43.000Z, random:false, isRandomEnabled:false, rssi:-33, residenceId:229239, residentialRoomId:275242, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153696769, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-0C-F0-09, logging:0, resOcc:0, customType:dimmer, iotBridgeId:null, iotBridgeSerial:null, id:388409]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.909 pm [**debug**](http://///Local IP////device/edit/5)resp.data = [[name:Living Room Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:100, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_000B_D1F4, version:1.5.72; CP 1.13, minLevel:10, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:, buttonData:, linkData:, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.20, created:2019-08-24T01:13:49.000Z, lastUpdated:2021-06-20T21:56:43.000Z, random:false, isRandomEnabled:false, rssi:-33, residenceId:229239, residentialRoomId:275242, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153696769, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-0C-F0-09, logging:0, resOcc:0, customType:dimmer, iotBridgeId:null, iotBridgeSerial:null, id:388409], [name:Kitchen Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:100, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_0006_DDBF, version:1.5.72; CP 1.9, minLevel:1, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:AAAAAA==, buttonData:null, linkData:null, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.38, created:2019-09-27T20:26:42.000Z, lastUpdated:2021-06-20T22:25:36.000Z, random:false, isRandomEnabled:false, rssi:-55, residenceId:229239, residentialRoomId:null, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153889329, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-07-EB-10, logging:0, resOcc:0, customType:null, iotBridgeId:null, iotBridgeSerial:null, id:406587]]
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:56.708 pm [**debug**](http://///Local IP////device/edit/5)httpGetExec([uri:https://my.leviton.com/api/Residences/229239/iotSwitches, headers:[Authorization:///authorization token removed by me///], contentType:application/json])
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:39.775 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"chgReason":3,"lastUpdated":"2021-06-20T22:25:35.599Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:25:39.226 pm [**debug**](http://///Local IP////device/edit/310)respData = [name:Kitchen Dimmer, power:ON, identify:0, ota:false, cloud_ota:false, downloaded:0.0.0, brightness:100, manufacturer:Leviton Manufacturing Co., Inc., model:DW6HD, serial:1000_0006_DDBF, version:1.5.72; CP 1.9, minLevel:1, maxLevel:100, fadeOnTime:0, fadeOffTime:0, presetLevel:0, dimLED:3, statusLED:255, loadType:1, canSetLevel:true, isAlexaDiscoverable:true, includeInRoomOnOff:true, timeZone:-300, lat:36.19, long:-79.19, env:3, programData:AAAAAA==, buttonData:null, linkData:null, dstStart:1615705200, dstEnd:1636264800, dstOffset:60, autoOffTime:0, connected:true, localIP:192.168.86.38, created:2019-09-27T20:26:42.000Z, lastUpdated:2021-06-20T22:25:34.937Z, random:false, isRandomEnabled:false, rssi:-55, residenceId:229239, residentialRoomId:null, deleted:false, blink:0, onTime:0, position:null, connectedTimestamp:1624153889329, timeZoneName:America/New_York, apply_ota:0, otaStatus:2, lang:null, audio_cue:null, mic_mute:null, configuredAmazon:null, resKey:3971697493, allowLocalCommands:null, mac:00-07-A6-07-EB-10, logging:0, resOcc:0, customType:null, iotBridgeId:null, iotBridgeSerial:null, id:406587]
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:25:39.215 pm [**debug**](http://///Local IP////device/edit/310)httpAsyncCallback **with** status = 200 **from** data = null
[dev:5](http://///Local IP////logs#dev5)2021-06-20 06:25:39.114 pm [**debug**](http://///Local IP////device/edit/5)parse: {"type":"notification","notification":{"event":"saved","modelName":"IotSwitch","modelId":406587,"data":{"power":"ON","lastUpdated":"2021-06-20T22:25:34.937Z"}}}
[dev:310](http://///Local IP////logs#dev310)2021-06-20 06:25:38.901 pm [**debug**](http://///Local IP////device/edit/310)httpPutExec([uri:https://my.leviton.com/api/IotSwitches/406587, headers:[Authorization:///authorization token removed by me///], contentType:application/json, body:[power:ON]])
