I have a Leviton VRPA1. It is not on the list. It is a 1/2 hp motor controller. Can I use this device to control Lights on/off? I have previous used it for that in Vera.
It seams to me that it should work again. If your answer is yes, then what label should
I give it?
Try using generic z-wave plus outlet driver.
If the z-wave plus driver doesn't work, try the "Generic Z-Wave Outlet" driver. Those Vizia units were z-wave, but had instant status - not sure how Leviton did that (probably using Hail).
I have 2 of these working with Generic Z-wave Switch driver.
Thanks guys,
Did not work for me. Replaced with proper switch.
did you click configure after changing the driver?
Change driver
Click save
click configure. Wait one minute, try using
