Leviton Decora no neutral Leviton DN15S-2RW switch
I can install this switch for Alexa or homekit and I'm wondering if I do and have the Alexa and Homekit app installed on Hubitat will I beable to see the switch in my Hubitat dashboard? I'm trying to solve a problem with a couple of switches that don't have neutral wires by using this switch and it's associated wi-fi bridge.
Devices setup in HomeKit or Alexa cannot currently be shared with Hubitat. However, there is at least one workaround that I am aware of (and have used).
You can create a virtual switch in Hubitat that is shared with Alexa or HomeKit that is turned on/off via an Alexa Routine (I suspect the same can be done in HomeKit)
