Its been awhile, but setting up the Bond hub was just going through it's setup. Add a shade and learn the remote, I think. If I remember correctly I had to learn the remote for each shade. Maybe I only had to do it once I really cant remember.
Once you can control the shades with the bond hub and app you then need the HE app and driver to control them through HE. I am using the community version of the Bond hub integration. The built in HE version will work but it will only fully open or close the shade. I actually had to modify the community driver to use a command so I could raise and lower the shade to the next setpoint. When using the bond app there is a Open Next and Close Next item for each shade. This will move the shade to it's next programmed setpoint. I could not get the developer of the community app to add it, so I did it myself. I think the community developer had stopped supporting the app, but I had the same issue with the HE team. I requested they add it but they never would even respond to me, saying yes or no that they would do it. So I just keep using the community version, which is available through HPM.
I assume you are aware but you can integrate through HE using the Leviosa Zone. I used the zone for quite some time. It has an Alexa integration and I used echo speaks to send voice commands. That worked pretty well, but it was not local and will not work if internet is down. The bond integration is local and you can control the shades locally with no internet.
