Level Lock with Matter Pairing Error
I'm trying to pair my Level Lock Bolt with matter. I'm using Apple Home with HomePod Mini as the Thread Border Router. Everything works fine in Apple Home. I have paired other Matter devices from Apple Home without problems. I use the pairing code generated by Apple Home in HE Add Devices so should be doing everything right.
When I try to pair with my C8-Pro I get the following error code:
Pairing failed @ sending AddNOC operational credentials command with code 80 (Unsupported certificate format)
Any suggestions?
Curious on this too. Looking into the Level Bolt
It's been a while since I paired mine, but I recall that HomeKit had issues with it. I used Alexa and it worked first time, then adopted into others.
I brought this up with Hubitat already and I imagine it will be fixed in a future version. Hubitat pumps out releases slower than me but faster than most :smiley:
The latest Release Notes v2.5.2 contains:
  • Matter attestation now uses CSA's DCL (online database) for device attestation, this should fix issues where devices have failed commissioning at the attestation phase.
  • Various fixes for matter certification, mostly related to BLE commissioning handoffs.
Any update on this? I had to repair my Level Bolt am now experiencing the same issue.
I have now successfully added my Level Bolt w/ Matter through Apple Home to Hubitat. I made several changes and I'm not sure which made the difference. I installed the most recent update to Hubitat (2.5.2.139) and updated my iPhone to the new OS 27 which updates Apple Home. I also added a new HomePod Mini 2 to my system in the same room as my lock.
I removed the Level Bolt from Apple Home, removed and reinstalled the battery, then used the Level App to connect back to Apple Home. I then created the pairing code in Apple Home and was able to add the Matter device using the code in Hubitat.
The lock added as a "Device" in Hubitat, so I had to change the 'Type' to a 'Generic Matter Lock' in the Device Info tab for the lock. Now all is working well.
Not sure if the new HomePod Mini made a difference or the HomePod being closer to the lock is important. I would suggest starting with the Hubitat update and the iPhone/Apple Home update, then the Level Bolt reinstall. Hope that works.
Thanks for the update! I'm still getting this error. The Google Home matter bridge is about 20' line of sight to the lock, so I don't know how it could be a signal issue. Any other ideas?
