I have two Level Locks in a Google Home environment. I installed a HomePod Mini based on the advice from a few posts that it is the best way to see and manage the locks in HE. I setup the locks in Apple Home and they work fine there, but only one of the two locks appeared in HE after enabling integration of the HE HomeKit App. I tried every idea to get this to work including rebooting the HomePod, deleting everything and starting over in both Apple and HE, and waiting a few days for the app to find the devices. After deleting the one found lock, I'm now unable to see either lock in HE when I run integration. Suggestions are appreciated - I will try them.
As far as I know, the Level lock is not supported in HE. You can, of course, set up virtual devices in HE and create automations within HomeKit to bring them into HE, but there is no native support.
In the future, Level claims that they will support Matter, at which time it won't... matter...
I'm looking for a way to know the locked/unlocked status of the Level lock for HE security routines.
Zero of the locks should have appeared if you did it this way. The HomeKit integration is for getting Hubitat devices into HomeKit.
For going the other direction, there is no easy way if your device is HomeKit-only. However, if your device is Matter -- and I'm not familiar with this device, but a casual Google search suggests it is supposed to be at some point -- then what you need is Hubitat's Matter integration, which is built-in and follows a similar process for adding other devices. See the "How to add a Matter Device" section here (or really just go to Devices > Add Device, select Matter, and follow the instructions for Apple Home or whatever Matter controller you are using):
But the post above suggest that it is not currently Matter. So the question is: how did you get it into Hubitat before? It couldn't have been HomeKit, at least not directly. (Some people create virtual devices and share those into HomeKit, along with some automations to "sync" things, as a workaround, but you would almost certainly remember having done that...)
Level has "promised" Matter support in the future, but nothing announced as of yet.
For what it's worth, I use a Level Bolt with HomeKit and use a virtual device within Hubitat, and it works well enough.
Thanks for your help. Do you know if it's possible to use a virtual device with Google Home to show the status of the Level locks in HE? Level integrates well with Google Home and I already have the Google equipment.
Can you please explain how you setup a virtual device in HE that will allow HE to see the locked/unlocked status of a Level Lock? I gave up on HomeKit and am using Google Home because most of my home devices are Google/Nest.
I need help setting up a virtual device or switch in HE that will allow HE to see the status of a device integrated with Google Home. The device is a lock and I want to know its lock/unlock status for Hubitat HSM routines.
I don't use Google Home, so someone who does may have to give you specifics. In general, voice assistants rarely let you directly share the status of any device, and the workaround is to bring a virtual device from the hub onto the voice assistant, create some sort of automation (routine, etc.) there using the virtual device as a "trigger," and gain control from Hubitat that way. If Google Home lets you use locks (such as this one) as a "trigger," you could maybe use a virtual device from the hub in your "actions" for that automation and change the state of this virtual device based on the state of the actual device (i.e, your trigger event). Often, this needs to be a virtual switch or other simple device rather than a virtual lock, which some systems may lack the ability to control, but again, I'm not familiar with Google specifically.
(Also, merging your duplicate post into this topic; please only do one or the other. Keeping it here since I responded here first...)
Thank you for the suggestions. I created a virtual switch in HE, imported it into GH and created a routine in GH to change its status. However, GH limits the options for lock routines to locking only. I need to know when the lock unlocks too. Any advice?
Would you please please explain this in further detail? Would greatly appreciate it.
I have one door that I've caught unlocked a few times, so I think it needs a smart lock.
I've been advised is not going be aesthetically revised, so at this point the Level Lock is my only option.
ETA: NM. I found this post that explains how to do it: Level Lock + HomeKit Integration + Hubitat
IIRC, before upgrading my level lock to matter and brining it into HE via Home Assistant, I used the virtual switches shared to HomeKit. I think I needed two sets of automation in HomeKit.
One set of automations opened or closed the level lock when the virtual switch opened or closed. The other set of automations opened or closed the virtual switch when the level lock opened or closed.
The second set was needed to keep the virtual switch in the correct state when the lock was activated manually or via HomeKit.
