Level Bolt getting Matter support
Level lock announced that a firmware update to enable matter over thread on the bolt products is now available. I submitted my request and can’t wait to apply it.
https://level.co/matter-update/
Looking forward to seeing this supported by Hubitat. I’ve had great luck with my level bolt. It has been more stable than my zwave locks.
No matter locks on the compatibility list. :crossed_fingers:t3:for 2.3.10 or 2.4. Might be a good idea to sign up for the next beta.
I may be confused. The OP stated the Level Lock will be Matter over Thread.
My understanding is Hubitat support Matter, but only over wifi since HE has no thread radio.
Hubitat can control Matter via Thread devices. A user needs to connect it to a Thread Boarder Router that is also a Matter Commissioner. Then a user can generate a new pairing code and connect the device to Hubitat. As long as the device is connected to a Thread Network and paired via Matter to Hubitat, it will work fine. See How to use Matter on Hubitat Elevation | Hubitat Documentation.
Right now, Hubitat does not support locks or buttons via Matter (regardless of WiFi or Thread). That will eventually come, and when it does, devices like the Level Lock will be controllable via Hubitat.
Thank you for the clarification. I guess what I see is that Matter over Thread needs a Thread Router. Then you can control if from that thread router or you can connect the thread router to Hubitat and control from there...
I'll wait for the Hubitat device with an internal thread router (but still with a Zwave and Zigbee router)
