Legrand Radiant WNRR15WH Smart Outlet (Fingerprint)
That’s the plan. I’ll report back when I have the new ones installed and a larger sample size to observe. Thanks!
Done. Good news, not-good news.
For a current picture, I now have 4 of these units added to my C7 hub.
I grabbed a 200W incandescent bulb (only ~$5!) and a socket-to-plug adapter from my local home center. I started with an known-good-for-power-reporting Jasco Zigbee receptacle to act as a control. That Jasco recept reported 204W from the bulb.
I then repeated the experiment with the 4 Legrand recepts that I have. All 4 Legrand recepts reported 21W back to the hub. (I'll just copy 1 of the log entries here, but all 4 look similar.)
@mike.maxwell , is this something that can be corrected in the Generic Zigbee Outlet driver?
Here's a shot of the device fingerprint if that helps any. Thanks!
Yes...
I have these as well, but don't have the reporting turned on. What do you have this set to?
I use '1 Watt' for all my Zigbee outlets just because I want to see the info. I believe the only consideration is radio/mesh traffic, but I'm happy to be corrected on that.
I can confirm the one I checked appears to be off by a factor of 10.
So... um, @mike.maxwell, does that "yes..." mean it WILL be corrected in the generic zigbee outlet driver? :wink:
I bought 6 of these - and they work great - but the scaling is the same as @JB_TX.
thanks!
Jann
yes
I picked one of these up at a decent price through Amazon Warehouse.
It pairs easily and the controlled outlet works fine.
The relay click is a bit loud, don’t know what to base it off of though.
It shows as a router but nothing has attempted to use it as such in the 4hrs it’s been online.
For those folks with this device is it playing nicely as a router and what sort of devices are using it?
@mike.maxwell Did the reporting get fixed in the generic driver or is that next release?
@ACKmySYN
I agree the clicking is loud. I really like how they can switch the second circuit though.
I don't see anything routing through mine at the moment.
Thanks, mine has connections now to other repeaters only, but I haven’t checked in a few days.
Any update on whether this outlet is playing nicely as a router?
