Continuing the discussion from LED Light strips with Bluetooth Control:
@adamkempenich could you describe your setup for TV bias lighting in more detail?
It matches what’s on the TV. It’s so slick.
That does look nice. However, if you want bias lighting for the purpose of decreasing eyestrain, then I strongly recommended trying white light at a color temperature of ~6500K.
And, speaking from personal experience (stuck 99% at home watching TV for the past ~2 months), it makes a huge difference on eye-strain. I have bias lighting upstairs, but not downstairs (yet). And I hate watching TV in bed now ....
What light source are you using, Ashok?
Definitely 6500k for that. Although, the color-shifting one has anecdotally been just as good as our cold-white TV setup. I’ll be interested in seeing what comes out as far as research goes on this.
(I just use an RGBWW light setup for the other TVs, with white turning on when the TV is on, and colors being used for security alerts)
Something cheap that works for 6500K - got them for about $10-15 a piece. Three of them placed behind a 55" TV works really well in my living room, and one of them behind a 40" TV in my guest room also works well.
I wish I'd done that for my bedroom TV also - didn't anticipate using it much.
Thanks guys. Looking for a very thin option for a new wall-mounted TV.
I might go with this one:
MediaLight Mk2 Flex 6500K CRI 98 Bias Lighting | MediaLight Bias Lighting.
Powered by TV USB port seems like a plus. I’m not sure if there’s a need to automate this since it should be ok if the bias lighting is on anytime the TV is.
That is nice!
