LED strips and controls
-Hello all.
TLDR: What product mix have others used for straight up tunable white that retains the cct you select and is dimmable at the switch?
I am new to Hubitat with a new house but was a long time Insteon user. I work in commercial / retail store lighting and building automation. So far so good with Hubitat and a lot of Zooz!
We have no LED in our house. Despite it being my business, the light quality is nowhere near incandescent, so we roll with a garage full of contraband and hope the light bulb police never show up ;). But now I have an application to backlight some things, and LED tape is the best solution due to geometry. I am looking for a zwave controller and tape that I can tune to a warm but not yellow color, have that color retained in memory, and then have on/off/dim controlled by a wall dimmer. No need for RGB, and don’t want a remote involved beyond setup and initial color tuning.
I know how to get it done in a commercial setting, but don’t need a theatrical solution for cove lighting in my guest bathroom.
Thanks!
Stephen
Here you go my friend. From a reputable vendor:
https://www.getzooz.com/zooz-zen31-rgbw-dimmer/
I don't know about recalling color, but I can do it with the Gledopto below, but should be the same with a Z-wave controller(not 100% sure)
You said Z-wave, but keep in mind Gledopto makes a Zigbee 3.0 controller that works very well.
Here it is: Amazon.com: GLEDOPTO ZigBee 3.0 Pro+ 3 in 1 RGBCCT/RGBW/RGB LED Strip Light Controller 20A Max Compatible with Amazon Alexa Homey Tuya Smart APP Voice Control Work with PWM Dimming LED Strip (Hub Required) : Tools & Home Improvement
Also the LED strips from BTF have many positive reviews here and elsewhere
Sorry for the delay, but thanks for the info. Not exactly where I’m going, but it sent me down a path that will work. Thank you!
