Hi,
I've been able to integrate older Somfy shades with a ZRTSI 16 channel zwave controller with little fuss into my HE (thank you community for the driver!), but I'm struggling searching for a clear path to integrate its current line of motors hubs.
Specifically the Sonnesse motor:
Questions:
is integrating through the Tahoma hub the most modern/best solution? or the MyLink plugin device?
if so has someone from the community coded a driver for it? I searched and couldn't find anything.
are there any improvements between "old" RTS and "new" RTS? IE shade sends positional state to hub, and is not limited by that garbage my position dual function button?
Thanks so much!
