Has anyone been successful in adding the Kwikset 918 with Z-wave LR to Hubitat and the Lock Manager?
Try the generic zwave lock driver.
I have seen people saying they got the Kiwkset 620 LR model paired no problem.
Are you looking to buy or are you having an issue?
If an issue you need to provide more details.
Can confirm. I just installed this lock yesterday for my friend. No problem pairing on a C-8.
I am looking at buying several for a new house. I am using an ultraloq pro at my current house. It doesn't work with the lock manager so I want to find a lock that will work. The z-wave LR appeals to me since the distances between the Hubitat and the locks will be greater.
Should be no issue because there's no issue with the LR version of the Kwikset SmartConnect 620.
There is no issue working with Lock Manager? That is where I found problems with my Ultraloq Pro.
None.
The issue with the Ultraloq is due to Ultraloq restricting access to lock codes to their mobile app. It is not due to any limitations within Hubitat or within Lock Code Manager.
Z-Wave locks from Kwikset, Schlage, and Alfred are not restricted in this manner. It is for this reason that I do not recommend locks from Ultraloq.
Great! Thanks for the help!
