Konnected Boards Added But No Devices Showing In Hubitat
I am in the process of switching to Hubitat from SmartThings but im having trouble getting my sensors and relays through Konnected to show up under devices. I have already tried reseting the boards and adding them again which is the only troubleshooting option i have been able to find so far.
Were you able to install the two apps for you panel type as well the drivers for each type of sensor?
Edit: info about installing it with hubitat is here:
I did install the two apps from GitHub but I couldn’t find anything about the drivers? Would you be able to explain where I can find those?
Have you looked this page?
The GitHub page has a bunch of drivers and you install the driver for each sensor type you want to install.
Edit: reworded for clarity.
That looks like it would definitely solve my problem! Thankyou so much!
Good luck!
Welcome!
And konnected is ace.
That worked! Thankyou for the help! and the welcome!
So I'm having the same issue the zone are not appearing under devices. I have the apps and the drivers. Went through the steps to add zones and name them as well as the output for the siren. Clicked done but nothing appears in my devices. Do have to Add them from the device tab or are they supposed to auto populate?
