Keypad functions
If I get one of the Centralite supported keypads, can I use it for other things in addition to arming and disarming the Safety Monitor?
For example, if a certain code is entered, have it turn off a particular automation? I would still want it to be able to arm & disarm the Safety Monitor using a different code.
I do that with mine using a RM rule. You can look for a particular code. Here is a simple example where I use a door lock, but the same principle works with a keypad.
Keypad%20Example
