KEVO Plus integration no longer authenticates
Has anyone noticed the Kevo integration can no longer authenticate? I have verified that I can login to mykevo.com with my username and password, but the integration fails to connect.
Before I dig into the possibility of forking the project in order to work on a fix, I was hoping by asking here, I could gauge what others are experiencing, and if other had this issue, what the fix was.
The integration stopped working a year ago or so.
It just loops with this, from bottom to top:
Received an error, attempting to relogin
Exception groovyx.net.http.HttpResponseException: status code: 405, reason phrase: The resource doesn't support specified Http Verb.
Token reading threw java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
Got cookie null
Got token response of 200
Getting token and cookie
I have been digging into the source. The Kevo backend was replaced with a new system that uses a real api and oath2. I am working on understanding the api and oath mechanisms, but have not worked out all the details yet.
