Keep Recirculated Hot Water Hot by Out Smarting Your Smart Tankless Heater
I had several posts asking for advice on how to activate a contact switch virtually. I want to post my use case and the solution I came up with so others can benefit from my use.
I had a tank water heater with a separate recirculation pump that I was controlling using a smart plug and several automations. I just switched to a tankless water heater - which is great. It has built-in recirculation features - but it left some holes in my needs.
My recirculation loop is VERY long - it takes nearly 2 minutes at 3.5gpm water flow to get hot water back to the heater. Built-in recirculation routines are designed to turn OFF the recirc pump as soon as a faucet is opened. The idea is, water is flowing TO the open faucet so why continue to pull water around the loop. Well, if the loop is long and the faucet opened is near the beginning, the water at the later faucets is stuck without immediate hot water.
In my previous configuration I used a combination of physical and/or virtual switches to turn on the recirc pump for 20 minutes (baths and kitchen) or 2.5 hours for dishwasher. The pump would run regardless of whether any faucets were open and the lines stayed (relatively) hot.
My new tankless water heater has several options - scheduled times of day where it recirculates for some amount of time every x minutes to keep the lines warm. "Smart" schedule where it "watches" your usage patterns over time and anticipates when you might want hot water (good for very regular people). And "push button" recirculation - where physical (door bell) buttons can be placed near faucets that will start a single manual recirc cycle to prime the lines. This is the most efficient method as you only recirculate just at time of need.
A few of problems arise out of the push button method (which I am using) in that if you push the button and then turn on a faucet before it primes, the pump turns off and you have to wait for the hot water to arrive. If the button (or another) is pushed while water is flowing, that request is ignored. If you start water flow before the ENTIRE line is primed the downstream faucets will still have to wait for the water to get there. And for high efficiency dishwashers - that only pull in a small amount of water, but do it every 15-20 minutes - it really sucks, especially if it is literally at the last stop in the line!
That was a lot - here is my (at least initial) solution:
Water Heater: Navien NPE-240A2
Smart Contact Switch: Fibaro FGBS-222 Smart Implant
Rule Machine:
1 Rule that activates based on multiple physical/virtual switches - starts a 20 minute timer and activates repeating rule
1 Repeating rule that activates the output of FGBS 222 and "pushes the recirc button on the water heater" which, if water is not flowing recirculates and if water is flowing is ignored - this repeats every 3 minutes (it takes 2 minutes to prime).
1 Rule that activates based on virtual "dishwasher" switch that starts a 2:30 timer to keep the recirc rule running
1 Rule that stops all the action based on two virtual switches (cancels all timers)
Initial testing looks good - if any timer is triggered after another the timers reset and whenever water is not actively flowing the recirc triggers every 3 minutes - that fills in the gaps and keep the water lines hot for the duration.
I have no doubt my 4 rules could be combined into a single rule - or an app written, but the logic of 3 of my rules has served me well for a couple of years and adding the repeating rule for the recirc was pretty easy.
If anyone is interested here are my rules:
HW - On
If any of these switches turns on
On: The Hot Water (virtual switch)
Set Global1 to true
Run Actions: HW - Recirc
Cancel Delayed Actions
Delay 0:20:00 (cancelable)
IF (Global2 = false) Off: The Hot Water
Set Global1 to false
HW - Recirc
Repeat every 0:03:00
	On: FGBS Implant - Output 1
END-REP
HW - Dishwasher
If Dishwasher (virtual switch) turn on
Set Global2 to true
On: The Hot Water
Delay 2:30:00 (cancelable)
If (Global1 = false) Off: The Hot Water
Set Global2 to false
HW - Off
If The Hot Water or The Dishwasher any turns off
Off: The Hot Water, The Dishwasher
Cancel Timed Actions: HW - Dishwasher, HW - On, HW - Recirc
Just stumbled on this. I am in exactly the same boat. Well controlled traditional water heater and external pump. New Navien and now using the internal recirculating pump.
I like your option. Presumably you are wiring the Fibaro directly to the contacts in the heater?
I am also looking at a thread on home assistant forums that has reverse engineered the Navien API when using the WiFi link to bring in more control and entities. But the NaviLink is $160 so not sure if the added value is there.
Correct.
Hi @DarellCraighead. I just got this installed and have the same model heater as you. I have a crossover valve on the farthest faucet that I was using with my external pump so left it in place. I assume you have a crossover valve - are you using the Navien branded valve? I compared the specs and it doesn't seem like I need their valve, or do I?
What I am seeing right now is that I activate the hot button and the heater runs for about 15 seconds and then shuts down each time. The behavior you describe with opening a faucet causing the recirculation to stop is in effect what it would look like if the crossover valve starts allowing water through to the cold line.
So I have several theories - the crossover valve is letting too much water through and causing the Navien to think that a faucet has been opened. Although the specs for the valves are almost identical.
There is a setting in the heater that I haven't found yet. I currently have it on External Recirculation, No External Pump, Hot Button and I have the valve inside the heater switched to EXT.
There is an excellent video on Youtube where someone did this a few years back on a slightly older model. They discussed changing the internal setting for the length of the run. I don't see a setting like that any more.
Thanks for your insights. I had this working great with an external pump on my old tank heater and looking forward to getting this working on the new one.
Our house was built with dedicated return line - no crossover. You DO need one though. The run time is adjustable in settings. You have to bump it up till water is hot at most distant faucet. PITA to set up initially because you have to let it cool each time before testing. My run takes almost 3 minutes- full loop.
Interesting. Would you happen to have any knowledge on where in the menus I can adjust the pump runtime and/or distance? I can't find it in my unit. I don't think this is related to the cross-over valve vs return line as I went through the different menus. The video online shows him adjusting it through the front panel using the + and - buttons but I have arrows instead of + and - and they do not respond in the way he suggested.
I am estimating that my furthest outlet is about 100 feet and it takes at least 60-90 seconds to bring hot water up. Thanks.
Look in INSTALLER manual
Thanks. Got it online. I see the settings now so will go to town.
