Keen Vents are not exposing important data in HE: the vents have a temperature sensor (which is reported when using SmartThings), and the data is accessible for automation in ST.
The reason I'd like to have this data available, perhaps with a real "HVAC vent" device type, rather than addressing it as a "dimmer" is simple - I'd like a rule that says "if the vent temperature is less than the room temperature sensor, close the vent".
This is to avoid blowing cold air into a room I'm trying to heat, during those first few minutes when the ducts are warming up.
Is it possible for RM to fully support the Keen vent data, rather than as a minimal "dimmer"?
(I'm not sure if this is a HE issue or a RM shortcoming, so I've also posted this issue in the Devices section of the forum.)
