I had to reset and re add the bulb. Added it into Habitat via the Kasa Integration app...
Went into the homekit app and the bulb shows in the incompatible list
Any trick to getting this bulb into the HomeKit integration?
WiFi devices should be integrated directly into HomeKit for Apple Certification. You can create a Virtual Bulb or Dimmer and integrate that with HomeKit. Then use the built-in Mirror app to control your Kasa bulb.
Yes, but unfortunately this is not a HomeKit enabled bulb and can’t be added direct.
The KL130 can’t be added directly.
Then use the virtual workaround I suggested.
Sounds good. Thanks!
Any chance that you can share a little bit of a tutorial here or direct me to some documentation.
