Kasa KP405 Dimming Plug errors when power removed
I use a Kasa KP405 Dimming outdoor plug for Christmas decorations. I do not have that plug powered all of the time. My automations do not turn off the plug. Instead, I just turn off power to the entire circuit. Any way to get rid of these error messages (about every 5 minutes when not powered). I suspect I get the messages because the plug is no longer powered. I have turned off all of the log messages in the "Kasa Dimming Switch" driver.
No. Not unless you disable the device in Hubitat. I will consider not logging warning after the error count exceeds 10 - but remember, you are still using Hub resources even w/o the message.
good point
