Kasa hs103p2 switch auto on
c8 pro 2.5.1.180
I have read that this switch can turn its self back on after you turn it off. I have been working in the settings of the kasa app but I can't get it to come back on. Does this work for anyone? Did i misunderstand that it can come back on after a min or 2?
There are two options:
Timer (on the app's device page). Will turn on or off after a specific time.
Smart Actions: Set up a smart action to run x minutes after the device is goes to the off state. The action would turn the device on.
This is what I was trying to do but it does not work on mine. It will not turn back on after something has turned it off. I did a search on it and the book says if it powers off then it can not power its self back on.
I'm looking all over at the device page and I can't come up with anything that looks like a timer. Could you point me in the right direction?
Exactly what are you trying to do? You could probably use the Hubitat rule machine.
Example,
I have a modem plus a separate router. The reset sequence is to turn off the modem, wait two minutes and turn it back on. Then turn off (Reboot) the router and turn it back on. Since my devices are all on my router / LAN (no cloud devices in this action), I can
a. Set up a Hubitat rule that detects the modem switch is off. When detected, turn the modem switch back on in two minutes.
b. I wait for the modem switch to turn back on, then I reboot the router over the web interface. (note that I can not switch the router off then on via Hubitat - once the router is off/rebooting, I have no LAN until the reboot finishes.
You can also do things in the Kasa/Tapo phone app (smart at the bottom of page). But be cautious. If you turn off the LAN router, Kasa will not be able to control a device to turn it back on.
Thanks. I appreciate your help.
After a bit of AI research, which I should have done before buying the device, I find that this particular device can not do anything other than turn off or turn on. No hardware control at all. I don't know about other Kasa devices, but this one is a simple one. Kasa hs103p2
Research tells me that to do what I want, I would need to go with wifi and use something like the Shelly Ver 4 devices.
