I have noticed that the kasa app shows an update available, but when I go to HPM there is nothing to update. I tried repair in HPM with same results. I believe this started with the previous hub update, not the one from this week.
Version of App you are on???
Kasa app is at 6.7.1
Hub is at 2.3.3.123
Did you press the configure button on one of your devices? This might update that field.
I do not see a configure button for the Kasa devices.
Then you do not have the 6.7.1 current drivers installed. Added configure to handle any IP address or other issues. Installation instructions say to run Configure on any one device. But you still have to have an app-driver version match.
I found the config box under the devices. I was looking in the app itself. I pushed config on each device and the app update tag went away. Thank you for your help!
This app is awesome, thanks Dave
