KAIPULE Z-Wave Plus Wireless Door and Window Sensor Got them paired pretty easy, only zwave door sensors i have as others are zigbee. Getting double open/closed messages and assume of course this is not normal but turning on debug i can see they are different commands. I'm not up on zwave commands, etc but i've tried searching to see what the difference is.
dev:2402020-12-01 10:13:36.295 pm debugparsed 'zw device: 19, command: 7105, payload: 00 00 00 FF 06 17 00 , isMulticast: false' to [[name:contact, value:closed, descriptionText:test1 was closed]]
dev:2402020-12-01 10:13:36.286 pm debugNotificationReport cmd:NotificationReport(v1AlarmType:0, v1AlarmLevel:0, reserved:0, notificationStatus:255, notificationType:6, event:23, sequence:false, eventParametersLength:0, eventParameter:[])
dev:2402020-12-01 10:13:36.279 pm debugparsed 'zw device: 19, command: 3003, payload: 00 0A , isMulticast: false' to [name:contact, value:closed, descriptionText:test1 was closed]
command 7105 and 3003, don't know why its reporting twice and if this is normal (assume not) and not sure how to fix it?? Normally i'd live with it but using node-red and getting two open and closes is a pain. Ideas? Not looking to work around the problem, looking to fix if at all possible. Do these modules just report this way?
