I just had a thought.
Is there a way to clear the logs without rebooting?
I ask because it would be nice if they could be cleared for trouble shooting to find out if I had the problem fixed.
Thanks for your guidance .
Paul
Paul
Your logs should have timestamps. If you're not seeing them, i would try another browser and see if it might be a browser issue. They are really helpful in determining the last time an issue occurred.
Also enabling debug logging can provide additional logs so you can see any errors in the context of any potential error.
Even with debug logging enabled, Time stamps really provide the accuracy to know for sure.
I understand both of those, it is 1 or 2 giving a error, and some warnings. Even using the filter, there were just so many to try and sift through. One problem I have is when I reboot the hub and clear the logs, when it reboots I get an error on a motion sensor for my bedroom right away.
On my PowerHouse c-7 hub, the Zigbee breakers are giving errors and warnings. Here is one error.
errororg.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'true' with class 'java.lang.Boolean' to class 'int' on line 1739 (method parse)
The warning page is long but here are a few lines
Home
Filter by date range
Search...
Apps and devices
120v Inside120v Outside220v InAirBattery TemperatureHeatHubitat Package Manager Updates AvailableMotionPowerhouse TemperatureTemp/Humidity Display
dev:2032026-04-20 02:08:00.345 AMwarn220v In Read attribute response: unsupported Attribute 0300 for Electrical Measurement cluster 0B04
dev:2032026-04-20 02:08:00.323 AMwarn220v In Tuya Cluster 0B04 unsupported attrId 0300
dev:3182026-04-20 02:08:00.294 AMwarn120v Outside Read attribute response: unsupported Attribute 0300 for Electrical Measurement cluster 0B04
dev:3182026-04-20 02:08:00.272 AMwarn120v Outside Tuya Cluster 0B04 unsupported attrId 0300
dev:2472026-04-20 02:08:00.213 AMwarn120v Inside Read attribute response: unsupported Attribute 0300 for Electrical Measurement cluster 0B04
dev:2472026-04-20 02:08:00.191 AMwarn120v Inside Tuya Cluster 0B04 unsupported attrId 0300
When I look at them, it is like reading a foreign language backwards. I do not know groovy yet.
I was going to ask @kkossev about it to figure out if it is something I am doing or something with the driver.
Thanks, I will keep trying.
Paul - there is a bug in the Tuya Zigbee Metering Plug driver, I will try to fix it as soon as I have the chance.
Update: please update the driver manually - ver. 2.0.3 2026-04-20
Let me know if the errors and the warnings are gone after updating the driver.
Hey there buddy, thanks. I don't know how to update the driver manually. Is it done in HPM or is there an import link?
Paul
I think I figured it out. I have two drivers right now butvi can fix that. The errors are gone but I am still getting warnings.
Apps and devices
dev:2472026-04-20 04:08:04.317 AM
warn
120v Inside Unprocessed ZDO command: cluster=8032 command=00 attrId=null value=null data=[00, 00, 0A, 01, 09, 7B, 69, 01, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00]
dev:2032026-04-20 04:08:02.958 AM
warn
220v In Unprocessed ZDO command: cluster=8032 command=00 attrId=null value=null data=[00, 00, 0A, 01, 09, 0A, 0B, 00, 0A, 0B, 7B, 69, 01, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00]
dev:2472026-04-20 04:08:02.833 AM
warn
dev:3182026-04-20 04:08:02.491 AM
warn
120v Outside Unprocessed ZDO command: cluster=8032 command=00 attrId=null value=null data=[00, 00, 0A, 01, 09, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00, 00, 00, 03, 00, 00
Turn the Debug logging off.
Ok, done and it is rebooting.
Fantastic! Thank you so much. No more errors or warnings now. Where is your donation link? I owe you a beer.
Paul
Nevermind, I found it on your profile.
Just to show, here is the messages now
Apps and devices
120v Inside120v Outside220v InBattery TemperaturePowerhouse Temperature
dev:562026-04-20 04:19:59.156 AMinfoBattery Temperature temperature is 51.36000000000001 °F
dev:3182026-04-20 04:19:55.171 AMinfo120v Outside voltage is 123 V
dev:2472026-04-20 04:19:54.924 AMinfo120v Inside voltage is 123 V
dev:1392026-04-20 04:19:54.223 AMinfoPowerhouse Temperature temperature is 50.95 °F
dev:2032026-04-20 04:19:48.624 AMinfo220v In voltage is 248 V
dev:3182026-04-20 04:19:48.291 AMinfo120v Outside Round-trip time is 0 ms
dev:3182026-04-20 04:19:47.903 AMinfo120v Outside Round-trip time is 0 ms
dev:2032026-04-20 04:19:39.394 AMinfo220v In power is 20 W
dev:2472026-04-20 04:19:39.374 AMinfo120v Inside power is 11 W
Thank you kossev. I thought I was doing something wrong. Lol
It good to hear it was not me. Hehehe
Have a blessed day!
I would like to clear and retain my uptime.
Yes, that is another reason I asked about clearing the logs without rebooting. Oh well, we can wish.
Any specific reason why? - The HE is known to have small/slow memory leaks and the occasional (every few weeks) reboot, isn't a bad thing - In fact lots of folks have weekly/monthly scheduled reboots done automatically.
100% this.
True. Hard to find something that runs in a JVM that doesn’t have slow memory leaks.
Edited for accuracy: ![]()
Hard to find something that runs in a JVM (or many members of this forum [points at self]) that doesn’t have slow memory leaks.
