Juno Connect control of color temp
I just got one of these tonight and was able to pair it to one of my hubs. It defaults to the Advanced Zigbee bulb. There's no Manufacturers data offered. I even switched to Device driver and did a Get Info resulting in an Unknown device message.
Switching to the Advanced Zigbee CT Bulb driver got everything working, including setting the Color Temp (2702 - 5000) even from the dashboard.
Factory reset is a difficult detail to find... so I'll mention it here: 5 power cycles cause the light to blink 3 times and it's 'factory reset.' To pair, I did the same, 5 power cycles. They can be at any speed. I tried ultra quick and very slow, both speeds worked the same.
dev:271 2021-12-27 06:13:26.766 pm debug getting info for unknown Zigbee device...
sys:1 2021-12-27 06:12:40.723 pm Zigbee Discovery Stopped
dev:271 2021-12-27 06:12:33.448 pm info Advanced Zigbee Bulb level was set to 20%
dev:271 2021-12-27 06:12:33.039 pm info Advanced Zigbee Bulb level was set to 100%
dev:271 2021-12-27 06:12:32.649 pm info Advanced Zigbee Bulb was turned on
dev:271 2021-12-27 06:12:32.502 pm debug finished options testing...
dev:271 2021-12-27 06:12:30.270 pm debug starting options testing...
sys:1 2021-12-27 06:12:27.281 pm Created Zigbee Device Advanced Zigbee Bulb
dev:27 12021-12-27 06:12:27.234 pm warn configure...
sys:1 2021-12-27 06:12:26.331 pm Initializing Zigbee Device 88571DFFFE6389B4, E3BF
sys:1 2021-12-27 06:12:18.121 pm Zigbee Discovery Running
sys:1 2021-12-27 06:12:15.549 pm Zigbee Discovery Stopped
sys:1 2021-12-27 06:11:15.598 pm Zigbee Discovery Running
--- Live Log Started, waiting for events ---
Screen Shot 2021-12-27 at 6.13.42 PM
https://www.lowes.com/pd/Juno-Connected-Wafer-Integrated-LED-6-in-75-Watt-Equivalent-Matte-White-Round-Dimmable-Canless-Recessed-Downlight/5000183151
