jbondc
August 2, 2022, 2:36pm
1
Hi,
I have music playing on several Sonos speakers and a rule for door contacts that plays a chime on the Sonos speakers.
I setup a rule to capture the last track and volume into 2 variables:
If a add second rule to check for 'TTS' (Text To Speech) being played:
Rule machine complains of JSON vs. string mismatch.
That's a bit odd since the hub variable 'Sonos_LastTrackData' is created as a String.
Is there some casting to JSON happening behind the scene?
How do I check for values in this variable in Rule Machine?
jbondc:
The attribute has the type indicated, and RM doesn't like comparing two different attribute types (since usually it makes no sense). Try putting that attribute into a String variable first, and then do the comparison.
jbondc
August 3, 2022, 12:50am
3
Doesn't seem like I can do what I want, what's the limit on string variables?
Blockquote
Variable length limit exceeded for Sonos_LastTrackData, value truncated, disposed: i-hls-static:ALkSOiEMib4caR-Lucs-6ejyCwOtsUWqmVhogjBHX_bYZyuw?sid=284&flags=8&sn=5","transportUri":"x-rincon-queue:RINCON_7828CAF404FE01400#0","enqueuedUri":"x-rincon-cpcontainer:0006002cALkSOiGp1ht9n_tIPhWYArzvTjlWBD1PFh3oZdwKLC0RZ5q2?sid=284&flags=44&sn=5","metaData":"Wintertime Warmth<\/dc:title>object.container.playlistContainer<\/upnp:class>Playlist<\/dc:creator>https:\/\/lh3.googleusercontent.com\/9CcRQ3Ez6tNGWSr8e2GvZihgOd_3IgLEldrGHIDXQpwTC4k78z3FuCIuXAznp32PR5EGSOorNeH9Cw=w544-h544-l90-rj<\/upnp:albumArtURI>Recently Played<\/r:description>SA_RINCON72711_X_#Svc72711-0-Token<\/desc><\/item><\/DIDL-Lite>","trackMetaData":"x-sonosapi-hls-static:ALkSOiEMib4caR-Lucs-6ejyCwOtsUWqmVhogjBHX_bYZyuw?sid=284&flags=8&sn=5<\/res><\/r:streamContent><\/r:radioShowMd>bd:0,sr:0,c:0,l:0,d:0<\/r:streamInfo>\/getaa?s=1&u=x-sonosapi-hls-static%3aALkSOiEMib4caR-Lucs-6ejyCwOtsUWqmVhogjBHX_bYZyuw%3fsid%3d284%26flags%3d8%26sn%3d5<\/upnp:albumArtURI>Let's Stay Together<\/dc:title>object.item.audioItem.musicTrack<\/upnp:class>Al Green<\/dc:creator>Let's Stay Together<\/upnp:album><\/item><\/DIDL-Lite>"}
I think I'm going to end up writing my own Sonos driver, I'd want crossfade as well.
https://developer.sonos.com/reference/types/play-modes/
Building a "smart home" sure isn't easy
