Based on my research I don’t believe this is possible, but I’d like to verify that here. My Jasco dimmer switch won’t dim my lights enough. Anything between 50-100 is almost identical. I was hoping for a way to calibrate the dimmer function.
This is likely to be a function of the light being controlled rather than the switch. put an incandescent bulb in as a test, and you will likely see a linear dim.
