Here is my latest version. I added issue above and resolved the issue with a button controlling the device hanging for a long time on commination failure.
* Copyright 2020-2022 Ivar Holand
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
metadata {
definition(name: "tuya Generic Device", namespace: "iholand", author: "iholand") {
capability "Actuator"
capability "Refresh" /* new */
capability "Switch"
capability "Sensor"
command "status"
attribute "availableEndpoints", "String"
preferences {
section("URIs") {
input "ipaddress", "text", title: "Device IP:", required: false
input "devId", "text", title: "Device ID:", required: false
input "localKey", "text", title: "Device local key:", required: false
input "endpoint", "text", title: "End point to control: ", required: true
input "tuyaProtVersion", "enum", title: "Select tuya protocol version: ", required: true, options: [31: "3.1", 33 : "3.3"]
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
def logsOff() {
log.warn "debug logging disabled..."
device.updateSetting("logEnable", [value: "false", type: "bool"])
def updated() {
// log.info "updated..."
log.warn "debug logging is: ${logEnable == true}"
if (logEnable) runIn(1800, logsOff)
sendEvent(name: "switch", value: "off")
if (logEnable) log.debug "Receiving message from device"
if (logEnable) log.debug(description)
byte[] msg_byte = hubitat.helper.HexUtils.hexStringToByteArray(description)
String status = new String(msg_byte, "UTF-8")
String protocol_version = ""
status = status[20..-1]
if (logEnable) log.debug "Raw incoming data: " + status
if (!status.startsWith("{")) {
// Encrypted message incoming, decrypt first
if (logEnable) log.debug "Encrypted message detected"
if (logEnable) log.debug "Bytes incoming: " + msg_byte.size()
def message_start = 0
// Find message type to determine start of message
def message_type = msg_byte[11].toInteger()
if (message_type == 7) {
// Incoming control message
// Find protocol version
byte[] ver_bytes = [msg_byte[48], msg_byte[49], msg_byte[50]]
protocol_version = new String(ver_bytes)
if (protocol_version == "3.1") {
message_start = 67
} else if (protocol_version == "3.3") {
message_start = 63
} else if (message_type == 10) {
// Incoming status message
message_start = 20
// Status messages do not contain version information, however v 3.3
// protocol encrypts status messages, v 3.1 does not
protocol_version = "3.3"
// Find end of message by looking for 0xAA55
def end_of_message = 0
for (u = message_start; u < msg_byte.size()-1; u++) {
if (msg_byte[u] == (byte)0xAA && msg_byte[u+1] == (byte)0x55) {
//msg end found
if (logEnable) log.debug "End of message: ${u-message_start-6}"
end_of_message = u-message_start-6
break
// Re-assemble the bytes for decoding
ByteArrayOutputStream output = new ByteArrayOutputStream()
for (i = message_start; i < end_of_message+message_start; i++) {
output.write(msg_byte[i])
byte[] payload = output.toByteArray()
if (logEnable) log.debug "Assembled payload for decrypt: "+ hubitat.helper.HexUtils.byteArrayToHexString(payload)
def dec_status = ""
dec_status = decrypt_bytes(payload, settings.localKey, true)
dec_status = decrypt_bytes(payload, settings.localKey, false)
if (logEnable) log.debug "Decryted message: ${dec_status}"
status = dec_status
try {
def jsonSlurper = new groovy.json.JsonSlurper()
def status_object = jsonSlurper.parseText(status)
sendEvent(name: "availableEndpoints", value: status_object.dps)
if (status_object.dps[endpoint] == true) {
if (txtEnable) log.info "${device.displayName} is on"
sendEvent(name: "switch", value : "on", isStateChange : true)
} else {
if (txtEnable) log.info "${device.displayName} is off"
sendEvent(name: "switch", value : "off", isStateChange : true)
try {
interfaces.rawSocket.close()
} catch (e) {
log.error "Could not close socket: $e"
} catch (e1) { //bad response, try to clear hung button
log.error "IP: $settings.ipaddress Endpoint: $settings.endpoint Parse response error: $e1"
String tstr = "null"
if (msg_byte != null) tstr = new String(msg_byte, "UTF-8")
log.error "raw data: $tstr"
if (status != null) log.error "status: $status" else log.error "status: null"
sendEvent(name: "switch", value : "failed", isStateChange : true)
def status() {
send(generate_payload("status"))
/* New */
def refresh() {
def on() {
send(generate_payload("set", ["${settings.endpoint}":true]))
def off() {
send(generate_payload("set", ["${settings.endpoint}":false]))
import hubitat.device.HubAction
import hubitat.device.Protocol
def send(byte[] message) {
try {
String msg = hubitat.helper.HexUtils.byteArrayToHexString(message)
if (logEnable) log.debug "Sending message to " + settings.ipaddress + ":" + 6668 + " msg: " + msg
//port 6668
interfaces.rawSocket.connect(settings.ipaddress, 6668, byteInterface: true, readDelay: 500)
interfaces.rawSocket.sendMessage(msg)
} catch (e) {
log.error "Error retry: $e"
if (txtEnable) log.info "${device.displayName} failure, turned off"
try { /* new retry */
String msg1 = hubitat.helper.HexUtils.byteArrayToHexString(message)
if (logEnable) log.debug "Sending message to " + settings.ipaddress + ":" + 6668 + " msg: " + msg1
//port 6668
interfaces.rawSocket.sendMessage(msg1)
} catch (e1) {
log.error "Error stop: $e1"
def generate_payload(command, data=null) {
def json = new groovy.json.JsonBuilder()
json_data = payload()["device"][command]["command"]
if (json_data.containsKey("gwId")) {
json_data["gwId"] = settings.devId
if (json_data.containsKey("devId")) {
json_data["devId"] = settings.devId
if (json_data.containsKey("uid")) {
json_data["uid"] = settings.devId
if (json_data.containsKey("t")) {
Date now = new Date()
json_data["t"] = (now.getTime()/1000).toInteger().toString()
//json_data["t"] = "1602184793" // for testing
if (data != null) {
json_data["dps"] = data
json json_data
if (logEnable) log.debug tuyaProtVersion
json_payload = groovy.json.JsonOutput.toJson(json.toString())
json_payload = json_payload.replaceAll("\\\\", "")
json_payload = json_payload.replaceFirst("\"", "")
json_payload = json_payload[0..-2]
if (logEnable) log.debug "payload before=" + json_payload
if (command == "set" && tuyaProtVersion == "31") {
encrypted_payload = encrypt(json_payload, settings.localKey)
if (logEnable) log.debug "Encrypted payload: " + hubitat.helper.HexUtils.byteArrayToHexString(encrypted_payload.getBytes())
preMd5String = "data=" + encrypted_payload + "||lpv=" + "3.1" + "||" + settings.localKey
if (logEnable) log.debug "preMd5String" + preMd5String
hexdigest = generateMD5(preMd5String)
hexdig = new String(hexdigest[8..-9].getBytes("UTF-8"), "ISO-8859-1")
json_payload = "3.1" + hexdig + encrypted_payload
} else if (tuyaProtVersion == "33") {
encrypted_payload = encrypt(json_payload, settings.localKey, false)
if (logEnable) log.debug encrypted_payload
if (command != "status" && command != "12") {
output.write("3.3".getBytes())
output.write("\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000".getBytes())
output.write(hubitat.helper.HexUtils.hexStringToByteArray(encrypted_payload))
} else {
if (tuyaProtVersion == "31") {
output.write(json_payload.getBytes())
if (logEnable) log.debug "payload after=" + json_payload
output.write(hubitat.helper.HexUtils.hexStringToByteArray(payload()["device"]["suffix"]))
byte[] bff = output.toByteArray()
if (logEnable) log.debug hubitat.helper.HexUtils.byteArrayToHexString(bff)
postfix_payload = bff
postfix_payload_hex_len = postfix_payload.size()
if (logEnable) log.debug postfix_payload_hex_len
if (logEnable) log.debug "Prefix: " + hubitat.helper.HexUtils.byteArrayToHexString(hubitat.helper.HexUtils.hexStringToByteArray(payload()["device"]["prefix"]))
output = new ByteArrayOutputStream();
output.write(hubitat.helper.HexUtils.hexStringToByteArray(payload()["device"]["prefix"]))
output.write(hubitat.helper.HexUtils.hexStringToByteArray(payload()["device"][command]["hexByte"]))
output.write(hubitat.helper.HexUtils.hexStringToByteArray("000000"))
output.write(postfix_payload_hex_len)
output.write(postfix_payload)
byte[] buf = output.toByteArray()
crc32 = CRC32b(buf, buf.size()-8) & 0xffffffff
if (logEnable) log.debug buf.size()
hex_crc = Long.toHexString(crc32)
if (logEnable) log.debug "HEX crc: $hex_crc : " + hex_crc.size()/2
// Pad the CRC in case highest byte is 0
if (hex_crc.size() < 7) {
hex_crc = "00" + hex_crc
crc_bytes = hubitat.helper.HexUtils.hexStringToByteArray(hex_crc)
buf[buf.size()-8] = crc_bytes[0]
buf[buf.size()-7] = crc_bytes[1]
buf[buf.size()-6] = crc_bytes[2]
buf[buf.size()-5] = crc_bytes[3]
return buf
// Helper functions
def payload()
def payload_dict = [
"device": [
"status": [
"hexByte": "0a",
"command": ["devId": "", "gwId": "", "uid":"", "t": ""]
"set": [
"hexByte": "07",
"command": ["devId":"", "uid": "", "t": ""]
"prefix": "000055aa00000000000000",
"suffix": "000000000000aa55"
return payload_dict
// Huge thank you to MrYutz for posting Groovy AES ecryption drivers for groovy
//https://community.hubitat.com/t/groovy-aes-encryption-driver/31556
import javax.crypto.spec.SecretKeySpec;
import javax.crypto.spec.IvParameterSpec;
import javax.crypto.Cipher
// Encrypt plain text v. 3.1 uses base64 encoding, while 3.3 does not
def encrypt (def plainText, def secret, encodeB64=true) {
// Encryption is AES in ECB mode, pad using PKCS5Padding as needed
def cipher = Cipher.getInstance("AES/ECB/PKCS5Padding ")
SecretKeySpec key = new SecretKeySpec(secret.getBytes("UTF-8"), "AES")
// Give the encryption engine the encryption key
cipher.init(Cipher.ENCRYPT_MODE, key)
def result = ""
if (encodeB64) {
result = cipher.doFinal(plainText.getBytes("UTF-8")).encodeBase64().toString()
} else {
result = cipher.doFinal(plainText.getBytes("UTF-8")).encodeHex().toString()
return result
// Decrypt ByteArray
def decrypt_bytes (byte[] cypherBytes, def secret, decodeB64=false) {
if (logEnable) log.debug "*********** Decrypting **************"
SecretKeySpec key = new SecretKeySpec(secret.getBytes(), "AES")
cipher.init(Cipher.DECRYPT_MODE, key)
if (decodeB64) {
cypherBytes = cypherBytes.decodeBase64()
def result = cipher.doFinal(cypherBytes)
return new String(result, "UTF-8")
import java.security.MessageDigest
def generateMD5(String s){
MessageDigest.getInstance("MD5").digest(s.bytes).encodeHex().toString()
def CRC32b(bytes, length) {
crc = 0xFFFFFFFF
for (i = 0; i < length; i++) {
b = Byte.toUnsignedInt(bytes[i])
crc = crc ^ b
for (j = 7; j >= 0; j--) {
mask = -(crc & 1)
crc = (crc >> 1) ^(0xEDB88320 & mask)
return ~crc
def socketStatus(String s) {
log.error "IP: $settings.ipaddress Endpoint: $settings.endpoint socketStatus: ${s}"
