I did not pay enough attention to Webcore when I upgraded from my C7 to the C8 hub and now I'm paying the price. I did have initial problems getting into Webcore right after I did the install. Logged out and cleared all registered browsers and that seemed to do the trick. I can get in and everything seems to be correct and working on the surface.
That said, pistons are not performing as well as they did before the hub upgrade, including sometimes not firing at all. I'm thinking it's because I never did a fresh install of the built-in version of Webcore in my Hubitat C8. I'm using version v0.3.114.
I'd like to back-up my pistons, uninstall my current version of Webcore from my C8 hub, reinstall the built-in version of Webcore, and then restore the pistons. I'm concerned that devices might not be recognized and that I'll have to rebuild my 27 pistons from scratch if I do so.
Any feedback and/or recommendations on how I should proceed to get Webcore working like it used to would be great. Also, if I do the reinstall as stated above, will it be an issue recognizing the devices and cause me to have to rebuild everything from scratch?
Any feedback would be greatly appreciated. Thanks!
Thanks for the feedback. I do have z-wave and even more zigbee devices.
Are you referring to the logs that I can turn on for each individual piston? I just flipped on medium logging for a couple of pistons that have clearly had issues.
Havent seen anything that seems unusual in the webcore logs.
I'm wondering if anyone knows specifically what will happen if i do as described in my first post above, which is:
Backup my pistons
Uninstall the webcore apps
Reinstall them
Restore the pistons
... Does anyone know if the pistons will "recognize the devices in Webcore" and run correctly?
I imagine when i have to reselect the devices after the reinstall, they will have new device ID's which will make them not recognizable by the pistons that where built from the devices before the unistall. Is that right?
Again, thanks for anyone who might be able to shed light on this potential solution to my problem.
