Issues with Harmony Hub
I ran into this issue as well with 2 of my 3 harmony hubs. Reset the hub and use the app to set it up again. When you do, you will have the option to restore from the configuration saved to their servers. If you do that, you'll be back to your original setup, and you should then be able to perform the normal setup functionality. This worked for me.
