Trying to create some simple mode lighting but each time I enter the bulb level for the first mode, the UI becomes unresponsive and the hub grinds to a halt.
They are Sylvania light strips using the generic zigbee RGBW driver. I'll try changing and testing. I just thought it was weird that I wasn't able to complete building the app.
In that case, I'd try inventing a Virtual Dimmer and see if the error still occurs. It's all native code so you've probably found a bug. Let's try and figure out which portion it's in.
Virtual dimmer- was able to complete creation of the app and it dimmed as expected with manual mode changes.
Generic z-wave RGBW bulb- hub froze after I entered the color and level for first mode and threw the same error as posted above.
Virtual RGBW bulb- after entering color and level for first mode, hub slowed to a crawl and eventually threw the same error. App page refreshed to an 'Unexpected Error' message and hub performance came back about 5 mins later.
My conclusion: Mode Lighting does not like setting levels for colored bulbs.
