Thanks for the suggestions.
Following is the logs taken after the rule was triggered.
It seems to confirm that the dimmer level value gets 'truncated' to the integer value of the required level by the fade routine. That results in the same level being requested more than once when the steps are below .5%.
Highlights:
AT 21:51:59, The rule to turn off light at 15% triggered and turned OFF light when dim level reached 15.84%) 22nd of 24 dimming steps
At 21:52:04: The light turned back ON when a dim command at level 15% was issued when fade calculated a level of 15.42%) (23rd step of 24 fading steps)
At 21:52:09: The light were dimmed at level 15% again when fade calculated a level of 15.0% (24 step and last of fading)
dev:642023-01-06 21:52:14.845infoEclairage corridor is 15% [digital]
dev:642023-01-06 21:52:14.842infoEclairage corridor is on [digital]
dev:642023-01-06 21:52:09.789infoEclairage corridor was set to 15% [digital]
dev:642023-01-06 21:52:09.783infoEclairage corridor is on [digital]
app:682023-01-06 21:52:09.405infoFinal Step Down: Eclairage corridor: Level 15
app:682023-01-06 21:52:04.828infoAction: Delay 0:03:00
app:682023-01-06 21:52:04.784infoTriggered: Eclairage corridor digital on
app:682023-01-06 21:52:04.774infoEvent: Eclairage corridor switch on
dev:642023-01-06 21:52:04.730infoEclairage corridor was set to 2% [digital]
dev:642023-01-06 21:52:04.727infoEclairage corridor was turned on [digital]
app:682023-01-06 21:52:04.345infoStep Down: Eclairage corridor: Level 15
dev:642023-01-06 21:52:00.018infoEclairage corridor was turned off [digital]
app:682023-01-06 21:51:59.763infoAction: Off: Eclairage corridor
app:682023-01-06 21:51:59.715infoWait over: Dimmer level of Eclairage corridor(15) reported <= 15
app:682023-01-06 21:51:59.688infoWait Event: Eclairage corridor level 15
dev:642023-01-06 21:51:59.658infoEclairage corridor was set to 15% [digital]
dev:642023-01-06 21:51:59.655infoEclairage corridor is on [digital]
app:682023-01-06 21:51:59.288infoStep Down: Eclairage corridor: Level 15
dev:642023-01-06 21:51:54.845infoEclairage corridor is 16% [digital]
dev:642023-01-06 21:51:54.842infoEclairage corridor is on [digital]
app:682023-01-06 21:51:54.234infoStep Down: Eclairage corridor: Level 16
app:682023-01-06 21:51:49.586infoWait Event: Eclairage corridor level 16
dev:642023-01-06 21:51:49.556infoEclairage corridor was set to 16% [digital]
dev:642023-01-06 21:51:49.554infoEclairage corridor is on [digital]
app:682023-01-06 21:51:49.166infoStep Down: Eclairage corridor: Level 16
dev:642023-01-06 21:51:44.491infoEclairage corridor is 17% [digital]
dev:642023-01-06 21:51:44.488infoEclairage corridor is on [digital]
app:682023-01-06 21:51:44.115infoStep Down: Eclairage corridor: Level 17
dev:642023-01-06 21:51:39.439infoEclairage corridor is 17% [digital]
dev:642023-01-06 21:51:39.436infoEclairage corridor is on [digital]
app:682023-01-06 21:51:39.065infoStep Down: Eclairage corridor: Level 17
app:682023-01-06 21:51:34.420infoWait Event: Eclairage corridor level 17
dev:642023-01-06 21:51:34.389infoEclairage corridor was set to 17% [digital]
dev:642023-01-06 21:51:34.386infoEclairage corridor is on [digital]
app:682023-01-06 21:51:33.998infoStep Down: Eclairage corridor: Level 17
dev:642023-01-06 21:51:29.338infoEclairage corridor is 18% [digital]
dev:642023-01-06 21:51:29.335infoEclairage corridor is on [digital]
app:682023-01-06 21:51:28.949infoStep Down: Eclairage corridor: Level 18
app:682023-01-06 21:51:24.293infoWait Event: Eclairage corridor level 18
dev:642023-01-06 21:51:24.264infoEclairage corridor was set to 18% [digital]
dev:642023-01-06 21:51:24.261infoEclairage corridor is on [digital]
app:682023-01-06 21:51:23.896infoStep Down: Eclairage corridor: Level 18
dev:642023-01-06 21:51:19.199infoEclairage corridor is 19% [digital]
dev:642023-01-06 21:51:19.197infoEclairage corridor is on [digital]
app:682023-01-06 21:51:18.821infoStep Down: Eclairage corridor: Level 19
dev:642023-01-06 21:51:14.141infoEclairage corridor is 19% [digital]
dev:642023-01-06 21:51:14.138infoEclairage corridor is on [digital]
app:682023-01-06 21:51:13.770infoStep Down: Eclairage corridor: Level 19
app:682023-01-06 21:51:09.105infoWait Event: Eclairage corridor level 19
dev:642023-01-06 21:51:09.076infoEclairage corridor was set to 19% [digital]
dev:642023-01-06 21:51:09.073infoEclairage corridor is on [digital]
app:682023-01-06 21:51:08.698infoStep Down: Eclairage corridor: Level 19
dev:642023-01-06 21:51:04.026infoEclairage corridor is 20% [digital]
dev:642023-01-06 21:51:04.023infoEclairage corridor is on [digital]
app:682023-01-06 21:51:03.648infoStep Down: Eclairage corridor: Level 20
app:682023-01-06 21:50:59.006infoWait Event: Eclairage corridor level 20
dev:642023-01-06 21:50:58.970infoEclairage corridor was set to 20% [digital]
dev:642023-01-06 21:50:58.967infoEclairage corridor is on [digital]
app:682023-01-06 21:50:58.582infoStep Down: Eclairage corridor: Level 20
dev:642023-01-06 21:50:53.915infoEclairage corridor is 21% [digital]
dev:642023-01-06 21:50:53.912infoEclairage corridor is on [digital]
app:682023-01-06 21:50:53.531infoStep Down: Eclairage corridor: Level 21
app:682023-01-06 21:50:48.933infoWait Event: Eclairage corridor level 21
dev:642023-01-06 21:50:48.903infoEclairage corridor was set to 21% [digital]
dev:642023-01-06 21:50:48.900infoEclairage corridor is on [digital]
app:682023-01-06 21:50:48.474infoStep Down: Eclairage corridor: Level 21
dev:642023-01-06 21:50:43.795infoEclairage corridor is 22% [digital]
dev:642023-01-06 21:50:43.792infoEclairage corridor is on [digital]
app:682023-01-06 21:50:43.422infoStep Down: Eclairage corridor: Level 22
dev:642023-01-06 21:50:38.746infoEclairage corridor is 22% [digital]
dev:642023-01-06 21:50:38.743infoEclairage corridor is on [digital]
app:682023-01-06 21:50:38.369infoStep Down: Eclairage corridor: Level 22
app:682023-01-06 21:50:33.726infoWait Event: Eclairage corridor level 22
dev:642023-01-06 21:50:33.692infoEclairage corridor was set to 22% [digital]
dev:642023-01-06 21:50:33.689infoEclairage corridor is on [digital]
app:682023-01-06 21:50:33.302infoStep Down: Eclairage corridor: Level 22
dev:642023-01-06 21:50:28.634infoEclairage corridor is 23% [digital]
dev:642023-01-06 21:50:28.631infoEclairage corridor is on [digital]
app:682023-01-06 21:50:28.250infoStep Down: Eclairage corridor: Level 23
app:682023-01-06 21:50:23.608infoWait Event: Eclairage corridor level 23
dev:642023-01-06 21:50:23.572infoEclairage corridor was set to 23% [digital]
dev:642023-01-06 21:50:23.569infoEclairage corridor is on [digital]
app:682023-01-06 21:50:23.195infoStep Down: Eclairage corridor: Level 23
app:682023-01-06 21:50:18.558infoWait Event: Eclairage corridor level 24
dev:642023-01-06 21:50:18.522infoEclairage corridor was set to 24% [digital]
dev:642023-01-06 21:50:18.519infoEclairage corridor is on [digital]
app:682023-01-06 21:50:18.130infoStep Down: Eclairage corridor: Level 24
app:682023-01-06 21:50:13.102infoAction: Wait for event: Dimmer level of Eclairage corridor(25) is <= 15
app:682023-01-06 21:50:13.079infoStep Down: Eclairage corridor: Level 24
app:682023-01-06 21:50:13.051infoAction: Lower Eclairage corridor down to 15 over 2 minutes with 5.0 seconds interval
app:682023-01-06 21:50:13.039infoDelay Over: Delay 0:03:00
dev:632023-01-06 21:48:18.340infoMotion / Temp: motion is inactive
