Thank you
Yes I use one of those in a different size, connected to an ecolink z-wave contact sensor.
Your the best. I knew Iād find an answer here. Do you think the 25lb force is sufficient for under a mattress, or opt for the 60lb one?
I put one of the 60 lb mats under my living room couch. I was concerned the 25 lb would trigger too easily, but I am finding that the 60 lb mat might be too far the other way, ie it sometimes doesnt trigger when it should.
So if I had to do it again, I might try a 25 lb mat, but that still could cause issues from false triggers...
Thank you
