I have a light that I want in my garage that screws into the outlet in the ceiling. I would like to control it with a zooz motion sensor. Is there somekind of zwave E27 outlet adapter?
I havenβt seen one of those in years but there are swabs bulbs. Aeotec makes a nice one.
This is the, "bulb" I use. A regular bulb (even bright daylight) isn't bright enough. It screws in like a light bulb into a regular E27 socket. https://smile.amazon.com/dp/B08GNZVZZT/ref=cm_sw_r_cp_apa_i_8wX-Fb72MT2FP?_encoding=UTF8&psc=1
Might be easier to add a Z-Wave switch and have the motion sensor trigger it....
That being said this might work:
Itβs discontinued but Amazon still has some...
That's actually in the plans, but the way this houses wired is beyond my skill level, and will require an electrician, and will involve about 5 or 6 switches when the time comes. That being said, I'm looking for a relatively cheap temp solution, and that outlet might just do the trick, Thanks!
Yep. This solved my immediate issue. As I said, eventually I'm going to put in led shop lights on a zwave switch, but this works great now. When I do, this little device will likely find its way to the attic. I have a bad habit of forgetting to turn that light off. Thanks for the suggestion!
