Connecting to HE creates too many switches.
Fake "Component Devices" will reappear even if cleared.
Data
endpointId: 01
hasMultiEP: true
application: 5A
softwareBuild:
driver: v1.0.1.1123b
inClusters: 0000,0004,0003,0006,0005,0002,000A,FCC0,0B04
outClusters: 0019,000A,FCC0
model: lumi.switch.n3acn3
manufacturer: LUMI
Component Devices
Aqara SW3 01 (Device 01)
Aqara SW3 02 (Device 02)
Aqara SW3 03 (Device 03)
Aqara SW3 15 (Device 15)
Aqara SW3 1F (Device 1F)
Aqara SW3 29 (Device 29)
Aqara SW3 2A (Device 2A)
Aqara SW3 2B (Device 2B)
Aqara SW3 33 (Device 33)
Aqara SW3 34 (Device 34)
Aqara SW3 35 (Device 35)
Aqara SW3 3D (Device 3D)
Device pairing info
| Manufacturer: | LUMI |
| Endpoint 01 application: | 5A |
| Endpoint 01 endpointId: | 01 |
| Endpoint 01 idAsInt: | 1 |
| Endpoint 01 inClusters: | 0000,0004,0003,0006,0005,0002,000A,FCC0,0B04 |
| Endpoint 01 initialized: | true |
| Endpoint 01 manufacturer: | LUMI |
| Endpoint 01 model: | lumi.switch.n3acn3 Z |
| Endpoint 01 outClusters: | 0019,000A,FCC0 |
| Endpoint 01 profileId: | 0104 |
| Endpoint 01 stage: | 4 |
| Endpoint 02 endpointId: | 02 |
| Endpoint 02 idAsInt: | 2 |
| Endpoint 02 inClusters: | 0000,0004,0005,0006,FCC0 |
| Endpoint 02 initialized: | true |
| Endpoint 02 profileId: | 0104 |
| Endpoint 02 stage: | 4 |
| Endpoint 03 endpointId: | 03 |
| Endpoint 03 idAsInt: | 3 |
| Endpoint 03 inClusters: | 0000,0004,0005,0006,FCC0 |
| Endpoint 03 initialized: | true |
| Endpoint 03 profileId: | 0104 |
| Endpoint 03 stage: | 4 |
| Endpoint 15 endpointId: | 15 |
| Endpoint 15 idAsInt: | 21 |
| Endpoint 15 inClusters: | 000C |
| Endpoint 15 initialized: | true |
| Endpoint 15 profileId: | 0104 |
| Endpoint 15 stage: | 4 |
| Endpoint 1F endpointId: | 1F |
| Endpoint 1F idAsInt: | 31 |
| Endpoint 1F inClusters: | 000C |
| Endpoint 1F initialized: | true |
| Endpoint 1F profileId: | 0104 |
| Endpoint 1F stage: | 4 |
| Endpoint 29 endpointId: | 29 |
| Endpoint 29 idAsInt: | 41 |
| Endpoint 29 inClusters: | 0012 |
| Endpoint 29 initialized: | true |
| Endpoint 29 profileId: | 0104 |
| Endpoint 29 stage: | 4 |
| Endpoint 2A endpointId: | 2A |
| Endpoint 2A idAsInt: | 42 |
| Endpoint 2A inClusters: | 0012 |
| Endpoint 2A initialized: | true |
| Endpoint 2A profileId: | 0104 |
| Endpoint 2A stage: | 4 |
| Endpoint 2B endpointId: | 2B |
| Endpoint 2B idAsInt: | 43 |
| Endpoint 2B inClusters: | 0012 |
| Endpoint 2B initialized: | true |
| Endpoint 2B profileId: | 0104 |
| Endpoint 2B stage: | 4 |
| Endpoint 33 endpointId: | 33 |
| Endpoint 33 idAsInt: | 51 |
| Endpoint 33 inClusters: | 0012 |
| Endpoint 33 initialized: | true |
| Endpoint 33 profileId: | 0104 |
| Endpoint 33 stage: | 4 |
| Endpoint 34 endpointId: | 34 |
| Endpoint 34 idAsInt: | 52 |
| Endpoint 34 inClusters: | 0012 |
| Endpoint 34 initialized: | true |
| Endpoint 34 profileId: | 0104 |
| Endpoint 34 stage: | 4 |
| Endpoint 35 endpointId: | 35 |
| Endpoint 35 idAsInt: | 53 |
| Endpoint 35 inClusters: | 0012 |
| Endpoint 35 initialized: | true |
| Endpoint 35 profileId: | 0104 |
| Endpoint 35 stage: | 4 |
| Endpoint 3D endpointId: | 3D |
| Endpoint 3D idAsInt: | 61 |
| Endpoint 3D inClusters: | 0012 |
| Endpoint 3D initialized: | true |
| Endpoint 3D profileId: | 0104 |
| Endpoint 3D stage: | 4 |
Summary
dev:532022-09-16 05:11:27.449 am infoUnhandled Event IGNORE THIS - description:read attr - raw: 4B962B00120A5500210100, dni: 4B96, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | msgMap:[raw:4B962B00120A5500210100, dni:4B96, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:532022-09-16 05:11:27.080 am debugsendOnOffEvent(endpoint=3, state=true)
dev:532022-09-16 05:11:27.077 am infoOn/Off Button press - description:read attr - raw: 4B960300061600001001F5002300964B03, dni: 4B96, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300964B03 | parseMap:[raw:4B960300061600001001F5002300964B03, dni:4B96, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:034B9600, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:532022-09-16 05:11:26.873 am infoUnhandled Event IGNORE THIS - description:read attr - raw: 4B962A00120A5500210100, dni: 4B96, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | msgMap:[raw:4B962A00120A5500210100, dni:4B96, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:532022-09-16 05:11:26.466 am debugsendOnOffEvent(endpoint=2, state=true)
dev:532022-09-16 05:11:26.463 am infoOn/Off Button press - description:read attr - raw: 4B960200061600001001F5002300964B03, dni: 4B96, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300964B03 | parseMap:[raw:4B960200061600001001F5002300964B03, dni:4B96, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:034B9600, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:532022-09-16 05:11:18.010 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:17.814 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:17.710 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:17.623 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:17.398 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:17.248 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:17.166 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 61 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:17.164 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 61 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:17.162 am debugcomponentRefresh() from 53-3D
dev:532022-09-16 05:11:17.150 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 61 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:17.148 am debugcomponentRefresh() from 53-3D
dev:532022-09-16 05:11:17.108 am infoMaking device with id 53-3D (name: Device 3D, label: Aqara SW3 3D)
dev:532022-09-16 05:11:17.105 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 53 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:17.102 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 53 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:17.101 am debugcomponentRefresh() from 53-35
dev:532022-09-16 05:11:17.094 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:17.088 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 53 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:17.086 am debugcomponentRefresh() from 53-35
dev:532022-09-16 05:11:17.044 am infoMaking device with id 53-35 (name: Device 35, label: Aqara SW3 35)
dev:532022-09-16 05:11:17.041 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 52 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:17.039 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 52 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:17.037 am debugcomponentRefresh() from 53-34
dev:532022-09-16 05:11:17.021 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 52 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:17.019 am debugcomponentRefresh() from 53-34
dev:532022-09-16 05:11:16.984 am infoMaking device with id 53-34 (name: Device 34, label: Aqara SW3 34)
dev:532022-09-16 05:11:16.981 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 51 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.978 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 51 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.976 am debugcomponentRefresh() from 53-33
dev:532022-09-16 05:11:16.966 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 51 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.964 am debugcomponentRefresh() from 53-33
dev:532022-09-16 05:11:16.947 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:16.930 am infoMaking device with id 53-33 (name: Device 33, label: Aqara SW3 33)
dev:532022-09-16 05:11:16.927 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 43 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.923 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 43 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.921 am debugcomponentRefresh() from 53-2B
dev:532022-09-16 05:11:16.910 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 43 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.908 am debugcomponentRefresh() from 53-2B
dev:532022-09-16 05:11:16.873 am infoMaking device with id 53-2B (name: Device 2B, label: Aqara SW3 2B)
dev:532022-09-16 05:11:16.870 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 42 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.868 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 42 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.866 am debugcomponentRefresh() from 53-2A
dev:532022-09-16 05:11:16.855 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 42 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.853 am debugcomponentRefresh() from 53-2A
dev:532022-09-16 05:11:16.815 am infoMaking device with id 53-2A (name: Device 2A, label: Aqara SW3 2A)
dev:532022-09-16 05:11:16.815 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:16.812 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 41 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.809 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 41 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.806 am debugcomponentRefresh() from 53-29
dev:532022-09-16 05:11:16.792 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 41 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.791 am debugcomponentRefresh() from 53-29
dev:532022-09-16 05:11:16.749 am infoMaking device with id 53-29 (name: Device 29, label: Aqara SW3 29)
dev:532022-09-16 05:11:16.746 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 31 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.743 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 31 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.741 am debugcomponentRefresh() from 53-1F
dev:532022-09-16 05:11:16.697 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 31 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.695 am debugcomponentRefresh() from 53-1F
dev:532022-09-16 05:11:16.646 am infoMaking device with id 53-1F (name: Device 1F, label: Aqara SW3 1F)
dev:532022-09-16 05:11:16.642 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:16.618 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 21 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.618 am debugchildren: [Aqara SW3 01, Aqara SW3 02, Aqara SW3 03, Aqara SW3 15]
dev:532022-09-16 05:11:16.608 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 21 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.606 am debugcomponentRefresh() from 53-15
dev:532022-09-16 05:11:16.596 am debugsendOnOffEvent(endpoint=3, state=false)
dev:532022-09-16 05:11:16.573 am infoOn/Off Button press - description:read attr - raw: 4B960300060A00001000, dni: 4B96, endpoint: 03, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00 | parseMap:[raw:4B960300060A00001000, dni:4B96, endpoint:03, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:532022-09-16 05:11:16.575 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 21 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.563 am debugcomponentRefresh() from 53-15
dev:532022-09-16 05:11:16.569 am debugchildren: [Aqara SW3 01, Aqara SW3 02, Aqara SW3 03, Aqara SW3 15]
dev:532022-09-16 05:11:16.538 am debugsendOnOffEvent(endpoint=3, state=false)
dev:532022-09-16 05:11:16.535 am infoOn/Off Button press - description:read attr - raw: 4B960300060A00001000, dni: 4B96, endpoint: 03, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00 | parseMap:[raw:4B960300060A00001000, dni:4B96, endpoint:03, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:532022-09-16 05:11:16.496 am infoMaking device with id 53-15 (name: Device 15, label: Aqara SW3 15)
dev:532022-09-16 05:11:16.491 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 3 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.488 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 3 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.486 am debugcomponentRefresh() from 53-03
dev:532022-09-16 05:11:16.471 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 3 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.469 am debugcomponentRefresh() from 53-03
dev:532022-09-16 05:11:16.463 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:16.463 am debugchildren: [Aqara SW3 01, Aqara SW3 02, Aqara SW3 03]
dev:532022-09-16 05:11:16.419 am debugchildren: [Aqara SW3 01, Aqara SW3 02, Aqara SW3 03]
dev:532022-09-16 05:11:16.414 am debugsendOnOffEvent(endpoint=2, state=false)
dev:532022-09-16 05:11:16.389 am infoOn/Off Button press - description:read attr - raw: 4B960200060A00001000, dni: 4B96, endpoint: 02, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00 | parseMap:[raw:4B960200060A00001000, dni:4B96, endpoint:02, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:532022-09-16 05:11:16.360 am debugsendOnOffEvent(endpoint=2, state=false)
dev:532022-09-16 05:11:16.339 am infoOn/Off Button press - description:read attr - raw: 4B960200060A00001000, dni: 4B96, endpoint: 02, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00 | parseMap:[raw:4B960200060A00001000, dni:4B96, endpoint:02, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:532022-09-16 05:11:16.311 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:16.277 am infoMaking device with id 53-03 (name: Device 03, label: Aqara SW3 03)
dev:532022-09-16 05:11:16.273 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 2 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.271 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 2 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.200 am debugcomponentRefresh() from 53-02
dev:532022-09-16 05:11:16.182 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 2 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.180 am debugcomponentRefresh() from 53-02
dev:532022-09-16 05:11:16.164 am debugsendOnOffEvent(endpoint=1, state=true)
dev:532022-09-16 05:11:16.156 am infoOn/Off Button press - description:read attr - raw: 4B960100060A00001001, dni: 4B96, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01 | parseMap:[raw:4B960100060A00001001, dni:4B96, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:532022-09-16 05:11:16.135 am debugsendOnOffEvent(endpoint=1, state=true)
dev:532022-09-16 05:11:16.128 am infoOn/Off Button press - description:read attr - raw: 4B960100060A00001001, dni: 4B96, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01 | parseMap:[raw:4B960100060A00001001, dni:4B96, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:532022-09-16 05:11:16.093 am infoMaking device with id 53-02 (name: Device 02, label: Aqara SW3 02)
dev:532022-09-16 05:11:16.083 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 1 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:16.070 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 1 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.068 am debugcomponentRefresh() from 53-01
dev:532022-09-16 05:11:16.034 am debugsendZigbeeCommands(cmd=[he rattr 0x4B96 1 0x0006 0x0000 {}, delay 206])
dev:532022-09-16 05:11:16.025 am debugcomponentRefresh() from 53-01
dev:532022-09-16 05:11:15.955 am debugBIND RESPONSE CLUSTER EVENT
dev:532022-09-16 05:11:15.921 am debugdirty model = lumi.switch.n3acn3, clean model=lumi.switch.n3acn3
dev:532022-09-16 05:11:15.920 am debugModel Name Received
dev:532022-09-16 05:11:15.914 am infoModel Name Received - description:read attr - raw: 4B960100002E050042126C756D692E7377697463682E6E3361636E33, dni: 4B96, endpoint: 01, cluster: 0000, size: 2E, attrId: 0005, encoding: 42, command: 01, value: 126C756D692E7377697463682E6E3361636E33 | parseMap:[raw:4B960100002E050042126C756D692E7377697463682E6E3361636E33, dni:4B96, endpoint:01, cluster:0000, size:2E, attrId:0005, encoding:42, command:01, value:lumi.switch.n3acn3, clusterInt:0, attrInt:5]
dev:532022-09-16 05:11:15.878 am infoMaking device with id 53-01 (name: Device 01, label: Aqara SW3 01)
dev:532022-09-16 05:11:15.854 am infoEndpoint Discovery Cluster Event- description:catchall: 0000 8005 00 00 0040 00 4B96 00 00 0000 00 00 0C00964B0C010203151F292A2B3334353D | parseMap:[raw:catchall: 0000 8005 00 00 0040 00 4B96 00 00 0000 00 00 0C00964B0C010203151F292A2B3334353D, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:4B96, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0C, 00, 96, 4B, 0C, 01, 02, 03, 15, 1F, 29, 2A, 2B, 33, 34, 35, 3D]]
dev:532022-09-16 05:11:15.817 am debugdirty model = lumi.switch.n3acn3, clean model=lumi.switch.n3acn3
dev:532022-09-16 05:11:15.813 am debugModel Name Received
dev:532022-09-16 05:11:15.808 am infoModel Name Received - description:read attr - raw: 4B960100002E050042126C756D692E7377697463682E6E3361636E33, dni: 4B96, endpoint: 01, cluster: 0000, size: 2E, attrId: 0005, encoding: 42, command: 01, value: 126C756D692E7377697463682E6E3361636E33 | parseMap:[raw:4B960100002E050042126C756D692E7377697463682E6E3361636E33, dni:4B96, endpoint:01, cluster:0000, size:2E, attrId:0005, encoding:42, command:01, value:lumi.switch.n3acn3, clusterInt:0, attrInt:5]
dev:532022-09-16 05:11:15.744 am debugsendZigbeeCommands(cmd=[zdo bind 4B96 1 0x01 0x0006 {00158D0007B896E2} {}, delay 187])
dev:532022-09-16 05:11:15.739 am debugsendZigbeeCommands(cmd=[he raw 0x4B96 1 0x01 0x0000 {10 00 00 05 00}, delay 2000])
dev:532022-09-16 05:11:15.736 am debugsendZigbeeCommands(cmd=[he raw 4B96 0 0 0x0005 {00 964B} {0x0000}, he raw 0x4B96 1 0x01 0x0000 {10 00 00 05 00}, delay 2000])
dev:532022-09-16 05:11:15.736 am debugSending request to read attribute 0x0005 from cluster 0x0000...
dev:532022-09-16 05:11:15.735 am debugrefresh cmd: [he raw 4B96 0 0 0x0005 {00 964B} {0x0000}, he raw 0x4B96 1 0x01 0x0000 {10 00 00 05 00}, delay 2000]
dev:532022-09-16 05:11:15.731 am infoSKIPPING ping() since there has been events received during the last 25 minutes...
dev:532022-09-16 05:11:15.731 am debugUpdated lastCheckinEpoch
dev:532022-09-16 05:11:15.730 am infoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:532022-09-16 05:11:15.729 am debugUpdated lastCheckin
dev:532022-09-16 05:11:15.728 am infoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:532022-09-16 05:11:15.720 am debugManufacturer Name Received
dev:532022-09-16 05:11:15.718 am infoManufacturer Name Received - description:read attr - raw: 4B9601000012040042044C554D49, dni: 4B96, endpoint: 01, cluster: 0000, size: 12, attrId: 0004, encoding: 42, command: 01, value: 044C554D49 | parseMap:[raw:4B9601000012040042044C554D49, dni:4B96, endpoint:01, cluster:0000, size:12, attrId:0004, encoding:42, command:01, value:LUMI, clusterInt:0, attrInt:4]
dev:532022-09-16 05:11:15.696 am debugdirty model = lumi.switch.n3acn3, clean model=lumi.switch.n3acn3
dev:532022-09-16 05:11:15.655 am debugsendZigbeeCommands(cmd=[he raw 0x4B96 1 0x01 0x0000 {10 00 00 04 00}, delay 2000])
dev:532022-09-16 05:11:15.651 am infoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:532022-09-16 05:11:15.649 am infoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:532022-09-16 05:11:15.645 am debugrecoveryMode: Slow
dev:532022-09-16 05:11:15.607 am infoRecovery feature ENABLED
dev:532022-09-16 05:11:15.605 am debugstartCheckEventInterval()
dev:532022-09-16 05:11:15.521 am infogetDriverVersion() = v1.0.1.1123b
dev:532022-09-16 05:11:15.519 am debugrefresh() model='lumi.switch.n3acn3'
dev:532022-09-16 05:11:15.517 am infoupdated()
dev:532022-09-16 05:10:23.310 am infofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0003,0006,0005,0002,000A,FCC0,0B04", outClusters:"0019,000A,FCC0", model:"lumi.switch.n3acn3", manufacturer:"LUMI"
dev:532022-09-16 05:10:23.229 am traceZCL version:01
dev:532022-09-16 05:10:23.225 am traceSoftware Build Id:unknown
dev:532022-09-16 05:10:23.218 am traceModel:lumi.switch.n3acn3
dev:532022-09-16 05:10:23.215 am traceManufacturer:LUMI
dev:532022-09-16 05:10:23.139 am debuggetting info for unknown Zigbee device...
dev:532022-09-16 05:10:21.120 am debugconfigure() called...
