Is there a way to trap a Null return from a Temperature Sensor?
I have a temp sensor that occasionally returns a 'Null' value. Is there a way of trapping this within Rule Machine?
Things I've tried:
Create a Virtual Temp sensor (Called Null Temp Sensor) and not set a reading, hoping that would be a Null value but it must create a default temp when created. The goal was to then check if the temp returned from the actual sensor was the same as my Null Temp Sensor device - that didn't work. :sleepy:
This sounds like an XY problem. What are you really trying to accomplish?
Hi and thanks for your reply.
Here is the rule for my Greenhouse heater:
I'm trying to stop an alert notification being sent if the the device returns a 'Null' result, rather than a low temperature reading.
Which of those notifications happen when you get a NULL? Do you have logs of the event happening?
Also: what's the temperature sensor and the device type it is using.
I'm trying to understand why you have the middle case. Is that just to get a repeated notification of continuing low temperatures? (I'm guessing if the heater isn't doing it's job)
This feels like the key to understanding what is happening.... At least the start to understanding the situation....
It's the middle one which, as you surmised, is to warn that the heater isn't managing to keep the temp above 3C.
I've tried changing the ElseIF statement to include a minimum condition as well to see if that stops the false notification:
The sensor is a Sonoff Temp Sensor (https://www.amazon.co.uk/gp/product/B08XB2QC3S/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1):
Update: Adding the minimum temp has resolved the issue.
