Title really says it all. I thought it might be under hub or zigbee properties but no sign of it.
It's listed in Hub Information Driver 'Current states' so it should be possible:
location.hub.zigbeeEui or location.hub.zigbeeId are the numbers you're showing,
Edit: @joshlobe (below) is correct in that there is a specific Pan ID data item that is a 4 character code.
location.hub.data.zigbeePanID
Thanks everyone.
Interestingly if I search "location.hub.data" in the community or the documentation, this thread is the only result.
Be nice if they included the extended PanID as well, but you can't have everything.
If you want to pull in a JSON string and process it you can use the endpoint:
http://<hub IP Address>hub2/zigbeeInfo
and look at the epan element
Thank you, this is excellent. Quite a lot of info there. I can also get message count and last message time which are of interest.
