Is there a way to discover Google Home voice commands for a given device?
The built in integration only allows the use of switches, dimmers, thermostats, and bulbs. The terminology is all based on those devices. So, if your garage door is integrated as a switch, it would be on/off instead of open/close.
If you wanted more flexibility and a better integration for the garage door, you need to look into [Alpha] Community-maintained Google Home integration. That community integration will give you more flexibility and a broader scope of devices that can be brought into Google Home.
