Is there a way to discover Google Home voice commands for a given device?
I'm wondering if there is a way to discover Google Home voice commands for a given device.
I installed a Konnected Blaq garage door control to my Chamberlain opener. So far I've figure out that I can turn the opener's light on and off by talking to Google Assistant via Hubitat's Google Home integration, saying "[device name] on|off". But I can't figure out if it's possible to open and close the door, or if so, what the voice command would be. It isn't "open" or "close"!
I'd like to list all commands available for this device.
The built in integration only allows the use of switches, dimmers, thermostats, and bulbs. The terminology is all based on those devices. So, if your garage door is integrated as a switch, it would be on/off instead of open/close.
If you wanted more flexibility and a better integration for the garage door, you need to look into [Alpha] Community-maintained Google Home integration. That community integration will give you more flexibility and a broader scope of devices that can be brought into Google Home.
