Is there a way to access the Device Enabled/Disabled attribute?
If there is such a thing....
This is the normally hidden column on the Device List page that has an "X" for a disabled device.
I tried a bunch, but no luck.
Thanks.
I don't know that I've seen a way to check the current status, just to enable/disable.
I haven't seen disabled/enabled as an attribute anywhere.
Do you have a clue how capture devices works? I tried it, not that it would help here, but couldn't figure out where it was captured to.
This is for capturing and restoring switch, dimmer, or bulb states (on/off, level, CT, or color). I do not believe Rule Machine has the ability to check the enabled/disabled state of a device. If you are writing a custom app, it is a property on the device object that you can view, however.
Thanks.
I don't have custom app writing skills, alas.
Perhaps there is a custom app out there that would provide access to this state?
