Is there a correct way to remove a setting?
Is there a correct way to remove - i.e., not update, but actually remove - a setting in the settings Map?
I have a multi-page custom application. In one page-navigation scenario, a user leverages the browser's back button and makes a change that causes one previously-entered setting to no longer apply.
While I can write the code to ignore the user's prior variable entry, my preference is to back out the input variable if there is a correct way to do so.
My FAILED Brute-Force Removal Attempt
settings = settings.findAll { it.key != 'X' }   // Where "X' is the key being backed out.
**Issue #1 (post attempted removal) **
The following discrepancy appeared "in the logs" AND on a user-input summary page (with data populated using "paragraph").
settings['X']     // reports null
settings.X        // reports null
X                 // reports prior value NOT null
Issue #2 (post attempted removal AND page refresh)
When I refreshed my summary page (after observing Issue #1), the "removed" KEY reappeared. Both the logs AND the summary page showed the "removed" KEY with its prior value.
You need to use removeSetting(). See: InstalledApp Object | Hubitat Documentation
The settings object itself should not be directly manipulated (same if you need to update a value).
In your case, something like this might work:
def settingNamesToRemove = settings.keySet()?.findAll { it != "x" }
settingNamesToRemove.each {
      app.removeSetting(it)
Perfect. Thanks!
