Is the Envisilink Integration a Resource Hog?
Admittedly, I just upgraded to .130, but I hadn't checked out the Envisalink's resource use in the logs.
For devices I get the following. Bear in mind that the HEM updates every 5 seconds and the presence sensors every 20 seconds.
The app's been very convenient and I like it a lot, but at what cost?
App stats:
The story isn't well told without a scale.. I enable "% of total"
Which, in my case, tells me the hub is at risk of forming icicles :smiley: Because the busiest App is 7/10 of a percent of the total capacity.
Mine is at 3.5% of total. A bit high, but I have about 20 devices on it and of course the nature of the constant streaming of info (whether anything happens or not) from the Envisalink board explains why it has to be this way.
Well worth the cpu cost IMO.
That's the benefit of Multiple Hubs when it gets to that point... 3.5% isn't enough, but add enough of those events, eventually intervals like that converge and Z-Stuff gets impacted. You've got far to go based on what I see, but maybe the next reader of this topic will be more congested. :smiley:
I actually have 2 hubs and for a while I had the envisalink on one with a few other things but I didn’t love the hub mesh and I was using Sharptools at the time for some extra configuration headaches.
Now I’m back to one production and one dev.
I rebooted the hub several times while experimenting with rule, and noticed the app was better behaved. :slight_smile:
FYI, on that app I’m developing I can have a filtered view of my Envisalink to just show open doors and windows on my dash. A real space saver.
Envisalink is very chatty. It's always my #2 app for resources.
I just checked and now that I'm on a C8 it's way down on the list for Apps/Devs using almost nothing, don't get why the C8 would change that.
My biggest offender now is Chromecast Helper chewing the cycles.
I don't think mine is too bad either:
The more time goes by, the better it looks. :slight_smile:
I'm surprised that the Fibaro Smart Implant (Buffer Tank) is up so high on the list. There are only 3 temperature probes, and it's not reporting that often.
As you can see mine is high today. Weird how it's variable it is from day to day. Usually it's about 3%.
I'm not aware of any software settings that could really cause my experience to be different from others, except perhaps polling which I have disabled. I have about 20 contacts and 2 smoke detectors and very little daily activity.
This caused me to take a quick look at the code. I'm not intimately familiar with it but seems that every incoming message is processed fully by parse(), however most of the time the new message is exactly the same as the prior one (because nothing has happened).
Perhaps I'm missing something but if the new message is exactly the same as the old message (probably 99% of the time in my case) then we should only need to process the message 1% of the time.
So I added this at the top of parse routine and I'm testing it out today.
def parse(String message) {
    ifDebug("Parsing Incoming message: [" + message + "]\n\n")
    state.lastMessage = state.thisMessage
    state.thisMessage = message
    //Check to see if the message has changed from the last one we received.
    //If it has not changed since the last message then we can just return as there is nothing new.
    if (message.toString() == state.lastMessage.toString()) {
        ifDebug("parse(): No change in Alarm state. Exiting.")
        return
Pre the change I used 2,500 seconds of CPU time in 13.5 hours. ~ 5%
Post the change I used 126 seconds of CPU time in 5 hours. ~ 0.7%
Big difference.
Needs some more monitoring but no issues so far, there again it's cold and rainy so not a lot of activity on the contact sensors.
Still running the modified code. Definitely more resources used than yesterday but only about 50% of what it was two days ago.
Today wasn't too bad here so there was a lot of in and out most of the day.
Looks good. If all goes well I'll patch my code to reduce the chatter.
I found and delete one msg a few years ago but I couldn't find this one.
Maybe while your'e in there you could silence this annoying info entrie in the logs? :slight_smile:
dev:1522023-04-28 05:18:51.996warntelnet input stream closed
You seem to have some big numbers.
My new weather stuff is now in the mix:
You have a rate of about 121,000/Hr and mine was 104,000/Hr.
Higher than I'd like, probably something to do with the telnet protocol is my guess.
