Just going to put it out there since I’m not sure if I’m just doing something wrong or if this is and expected behavior for thermostat controller.
Is there some setting or a rule that I can create that allows me or the people in my house to change the temperature on the physical thermostat, and let that be the new setting in thermostat controller?
On the thermostat itself, I’m not sure, unless there is a way with your thermostat driver to figure out if a change is physical (on the thermostat) or digital.
It would be possible to setup a virtual thermostat that could be adjusted by the family members from a dashboard or via Google or Alexa.
A rule could be created to detect changes to it and use that temperature instead of the set temperature for a set period of time.
