I just updated to the latest Webcore and Hubitat versions, and now this pistons no longer works. See the logs, it looks like it wants something that I cannot give. Is this a bug or did that functionality change?
BTW, since making those changes, a WAS condition also does not work, or at least, it is not consistent. Is that related?
Sorry, I'm not sure what to do. When I start the HPM, there are no packages available for me to install. I suppose I could manually install a back version of the 2 Webcore files by importing the code, which is what I did when I installed and recently updated the Webcore files, but I do not know how to find those. Is there a procedure that you could point me to?
I had been doing a manual update. In the last week, I probably did it 3 times. And each time I see that the Webcore main has changed. Doing it now, I see it changed again. Here is the latest that I can retrieve: @Field static final String sVER='v0.3.114.20220203' @Field static final String sHVER='v0.3.114.20230222_HE' @Field static final String sHVERSTR='v0.3.114.20230222_HE - March 28, 2023'
The previous versions were 3-30-23 for the Webcore file and 3-29-23 for the Piston file. Maybe I had trouble because I had a mismatch of file versions?
Before I updated both, I disabled all pistons, then once saved, I re-enabled the pistons. I'll need to let it run a while to see if all is fixed.
I did try to use HPM but I kept getting this message: Error logging in to hub
An error occurred logging into the hub. Please verify your Hub Security username and password.
But it does not tell me where to verify that.
Thanks for your help. Hopefully I'm back to running again.
