Is it possible to disable smart switch local relay control and if so how
Greetings, I'm relatively new to Hubitat but not to home automation. I have a GE Enbrighten Z-Wave smart switch that I installed for a lamp post. The intent was to create a dusk till dawn routine for the lamp post. I also have two lamp modules in the same room as that switch. I want to repurpose the buttons on the smart switch to control the lamp modules and just control the lamp post via the schedule. I know how to control the lamp modules from said switch but what I can't figure out is how to prevent the button presses from turning on and off the lamp post. It seems like the software for the switch needs to be edited but I'm not sure how to do that in Hubitat.
Any suggestions would be helpful.
Happen to know the model number?
The switch needs firmware that supports disengaging the switch from the relay (this is not a Hubitat issue per se). Zooz and iNovelli support that with their switches for sure. I don't know if GE/Jasco does.
